[mapguide-users] Re: Documentation for serving large raster imagesusing tile cache.
Jason Birch Jason.Birch at nanaimo.ca
Wed Nov 5 19:21:37 EST 2008
There is no task-specific documentation for this; basically you need to
set up a feature source for your rasters, create a layer that references
those rasters, and then create a map with a base layer group containing
that layer.  Once that is in place, you can either publish that map or
use the MapGuide APIs to interact with the tile cache directly.
Have you seen GeoWebCache?  It may be a closer fit for your tile needs,
and then any WMS server (including MapGuide) can host the source raster
images.
http://geowebcache.org/trac
Jason
Sent: Wednesday, November 05, 2008 15:51
Subject: [mapguide-users] Re: Documentation for serving large raster
	I am working on the stand alone java based application that
needs to serve up the images anywhere from 2GB to 30 GB.
	Could someone please point me to the documentation for serving
large raster images using tile cache. I want to use Map Guide to achieve
this. Any help is greatly appreciated. Thanks!
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081105/b375c3e1/attachment.html
