[mapguide-users] Erreur message ' Invalid repository type'
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Fri Nov 7 04:37:35 EST 2008
You cannot use MWF files with MapGuide Open Source or MapGuide Enterprise.
Those will only work with MapGuide 6.5.
Autodesk has a free "Migration" tool that can import a MWF file into
MGOS or MGE.
The studio url uses the resourceID:
Library://Ag Base/Mpg Urbanisme.WebLayout
Which is a valid weblayout resource ID.
Regards, Kenneth Skovhede, GEOGRAF A/S
Francis MILHAU skrev:
> I have another info : in mapguide studio, on my web publishing, the
> url on AJAX is :
> http://bayonne.ag-carto.fr/mapguide/mapviewerajax/?WEBLAYOUT=Library%3a%2f%2fAg+Base%2fMpg+Urbanisme.WebLayout&LOCALE=fr
> <http://bayonne.ag-carto.fr/mapguide/mapviewerajax/?WEBLAYOUT=Library%3a%2f%2fAg+Base%2fMpg+Urbanisme.WebLayout&LOCALE=fr>
>     -----Message d'origine-----
>     *De :* mapguide-users-bounces at lists.osgeo.org
>     [mailto:mapguide-users-bounces at lists.osgeo.org]*De la part de*
>     Francis MILHAU
>     *Envoyé :* vendredi 7 novembre 2008 09:48
>     *À :* MapGuide Users Mail List
>     *Objet :* RE: [mapguide-users] Erreur message ' Invalid repository
>     type'
>     The url is :
>     http://bayonne.ag-carto.fr/mapguide/mapviewernet/ajaxviewer.aspx?SESSION=&WEBLAYOUT=http://bayonne.ag-carto.fr/Mwf/40Seignanx/40312.MWF
>     <http://bayonne.ag-carto.fr/mapguide/mapviewernet/ajaxviewer.aspx?SESSION=&WEBLAYOUT=http://bayonne.ag-carto.fr/Mwf/40Seignanx/40312.MWF>
>     Regards
>         *Envoyé :* jeudi 6 novembre 2008 19:28
>         *Objet :* Re: [mapguide-users] Erreur message ' Invalid
>         repository type'
>         Somewhere you are passing a string that should start with
>         "Library://" but does not.
>         Perhaps you are loading the weblayout, but passing the string
>         like:
>         ?weblayout=MyLayout.WebLayout
>         when it should be
>         ?weblayout=Library://folder/MyLayout.WebLayout
>         What url does the page have that emits the error message?
>>         Hi,
>>         When i try to load my application developped with mapguide
>>         studio , withe Internet explorer i have this message :
>>         /*Invalid repository type.
>>         Invalid repository type. Exception occurred in method
>>         MgResourceIdentifier.CheckType at line 716 in file
>>         d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\common\platformbase\Services/ResourceIdentifier.cpp*/
>>         Have you an idea ?
>>         thanks
>>         Francis
>>         Configuration : Client/Server
>>         PC under Windows 2003 Server , SP2
>>         IIS 7
>>         Mapguide Server OpenSource 2.0.1
>>         Geomap Server 5.6
>>         Autodesk Mapguide Studio 2.0
>>         My test :
>>         http://localhost/ggWeb2009/ggMain.aspx?version=5&target=AJAX
>>         <http://localhost/ggWeb2009/ggMain.aspx?version=5&target=AJAX>
>>         _______________________________________________
>>         mapguide-users mailing list
>>         mapguide-users at lists.osgeo.org
>>         http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081107/461e4968/attachment.html
