[mapguide-users] Erreur message ' Invalid repository type'
Francis MILHAU
fmilhau at ag-carto.fr
Fri Nov 7 06:26:15 EST 2008
Ok, i have understand and corrected my application
thanks a lot
Francis
-----Message d'origine-----
De : mapguide-users-bounces at lists.osgeo.org
[mailto:mapguide-users-bounces at lists.osgeo.org]De la part de Kenneth
Skovhede, GEOGRAF A/S
Envoyé : vendredi 7 novembre 2008 10:38
À : MapGuide Users Mail List
Objet : Re: [mapguide-users] Erreur message ' Invalid repository type'
You cannot use MWF files with MapGuide Open Source or MapGuide Enterprise.
Those will only work with MapGuide 6.5.
Autodesk has a free "Migration" tool that can import a MWF file into MGOS
or MGE.
The studio url uses the resourceID:
Library://Ag Base/Mpg Urbanisme.WebLayout
Which is a valid weblayout resource ID.
Regards, Kenneth Skovhede, GEOGRAF A/S
Francis MILHAU skrev:
I have another info : in mapguide studio, on my web publishing, the url
on AJAX is :
http://bayonne.ag-carto.fr/mapguide/mapviewerajax/?WEBLAYOUT=Library%3a%
2f%2fAg+Base%2fMpg+Urbanisme.WebLayout&LOCALE=fr
[mailto:mapguide-users-bounces at lists.osgeo.org]De la part de Francis MILHAU
Envoyé : vendredi 7 novembre 2008 09:48
Objet : RE: [mapguide-users] Erreur message ' Invalid repository type'
The url is :
http://bayonne.ag-carto.fr/mapguide/mapviewernet/ajaxviewer.aspx?SESSI
ON=&WEBLAYOUT=http://bayonne.ag-carto.fr/Mwf/40Seignanx/40312.MWF
Regards
Envoyé : jeudi 6 novembre 2008 19:28
type'
Somewhere you are passing a string that should start with
"Library://" but does not.
Perhaps you are loading the weblayout, but passing the string like:
?weblayout=MyLayout.WebLayout
when it should be
?weblayout=Library://folder/MyLayout.WebLayout
What url does the page have that emits the error message?
When i try to load my application developped with mapguide studio
, withe Internet explorer i have this message :
Invalid repository type.
Invalid repository type. Exception occurred in method
MgResourceIdentifier.CheckType at line 716 in file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\common\pla
tformbase\Services/ResourceIdentifier.cpp
Have you an idea ?
thanks
Francis
Configuration : Client/Server
PC under Windows 2003 Server , SP2
IIS 7
Mapguide Server OpenSource 2.0.1
Geomap Server 5.6
Autodesk Mapguide Studio 2.0
My test :
http://localhost/ggWeb2009/ggMain.aspx?version=5&target=AJAX
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081107/29b27fd7/attachment.html
