[mapguide-users] Tracking vehicles, Displaying positions
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Fri Nov 7 04:42:05 EST 2008
I have not tried to use DWG or DXF in MapGuide.
There exists a patch that will enable the OGR provider to use DXF data,
but you will have to build a new OGR provider yourself, as it is not
included in the official build (something about licenses...):
http://trac.osgeo.org/gdal/browser/spike/dxfdwg
Regards, Kenneth Skovhede, GEOGRAF A/S
Carmelo Saffioti skrev:
> Hi Kenneth,
> thank you for your suggestion. I stored NMEA data with separate
> columns for lat/lon...
> Regarding DWG import, I'd like open source solutions, do you know
> anything about? DWG is proprietary, but if I export to DXF is there
> any open source solution to import it into MapGuide?
> Cheers
> Carmelo
>     ----- Original Message -----
>     *From:* Kenneth Skovhede, GEOGRAF A/S <mailto:ks at geograf.dk>
>     *To:* MapGuide Users Mail List
>     <mailto:mapguide-users at lists.osgeo.org>
>     *Sent:* Thursday, November 06, 2008 9:17 AM
>     *Subject:* Re: [mapguide-users] Tracking vehicles, Displaying
>     positions
>     Hi Carmelo.
>     If you pre-process your NMEA data and extract lat/lon values into
>     columns, you
>     can use the ODBC provider and make points of the columns.
>     I would suggest some kind of service that regularly does this on
>     the MySql server.
>     Since DWG is a proprietary format, you can't do it with open
>     source tools.
>     Autodesk MapGuide Studio can import a DWG for you, and it is
>     fairly inexpensive.
>>     Hi everybody,
>>     I need to develop a system for tracking and displaying vehicles
>>     positions. I'm storing NMEA gps sentences into a MySql DB. Now I'd
>>     like to display these positions on a map. How can I do? I'm new to
>>     this, can you give me any suggestion?
>>     I have to create the map too, because this zone is not mapped. Is it
>>     possible to create a map from a DWG cad file?
>>     I hope you can help me
>>     Cheers
>>     Carmelo
>>     _______________________________________________
>>     mapguide-users mailing list
>>     http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081107/372e2a42/attachment.html
