[mapguide-users] FeatureSource. PointTypeStyle? LineTypeStyle?
Greenhough, Jamie
JamieGreenhough at sierrasystems.com
Fri Nov 7 16:53:51 EST 2008
Thanks Kenneth. I have just begun using the Maestro API. Thanks again
for all your work on this.
Using this API to access the layer properties does sound easier than
using a layerfactory to generate the LayerDefinition XML.
So I think I will need to create the VectorLayerDefinition,
VectorScaleRange, PointTypeStyle, PointSymbolization2DType,
MarkSymbolType, PointTypeStyleType, and FillType. Then put all these
pieces together into a LayerDefinition.
Am I missing something? Do you have any maestro code snippets that will
jumpstart my dev on this?
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth
Skovhede, GEOGRAF A/S
Sent: Friday, November 07, 2008 1:59 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] FeatureSource. PointTypeStyle?
LineTypeStyle?
And some providers return the wrong results.
Rather than using the layerfactory method, have you tried the
MaestroAPI:
http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI
Using the MaestroAPI, you can access the "PointTypeStyle" (and all other
properties),
as a class rather than Xml.
Regards, Kenneth Skovhede, GEOGRAF A/S
Jackie C. Ng skrev:
Look at the class definition of the feature source it (the layer) is
referencing. More specifically, look at the geometry property and see
what
geometry types it supports. This will correspond with what styles you
can
have in your layer.
- Jackie
Greenhough, Jamie wrote:
I'm trying to programmatically add shape files as a
FeatureSource, and
then use a .NET layer factory (ported from PHP) to add a
LayerDefinition
to the MapGuide repository.
I can add the shape files and create a MapGuide FeatureSource
just
great.
I'm stuck with how to determine if the FeatureSource contains
Line or
Point data. Specifically the <PointTypeStyle> and
<LineTypeStyle> nodes
in the LayerDefinition.xml.
Does anyone have experience with this?
Thanks!
Jamie Greenhough | IT Consultant
Sierra Systems
----Notice Regarding Confidentiality----
This email, including any and all attachments, (this "Email") is
intended
only for the party to whom it is addressed and may contain
information
that is confidential or privileged. Sierra Systems Group Inc.
and its
affiliates accept no responsibility for any loss or damage
suffered by any
person resulting from any unauthorized use of or reliance upon
this Email.
If you are not the intended recipient, you are hereby notified
that any
dissemination, copying or other use of this Email is prohibited.
Please
notify us of the error in communication by return email and
destroy all
copies of this Email. Thank you.
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
http://themapguyde.blogspot.com
http://www.linkedin.com/in/jackieng
This email, including any and all attachments, (this "Email") is intended only for the party to whom it is addressed and may contain information that is confidential or privileged. Sierra Systems Group Inc. and its affiliates accept no responsibility for any loss or damage suffered by any person resulting from any unauthorized use of or reliance upon this Email. If you are not the intended recipient, you are hereby notified that any dissemination, copying or other use of this Email is prohibited. Please notify us of the error in communication by return email and destroy all copies of this Email. Thank you.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081107/cc33463e/attachment.html
