[mapguide-users] FeatureSource. PointTypeStyle? LineTypeStyle?
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Mon Nov 10 04:30:41 EST 2008
Unfortunately I have no snippets for that.
It should be robust enough to fix "mistakes" such as missing
collection/empty collection and the likes.
If you do manage to get through it, a sample would fit nicely here:
http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI
Regards, Kenneth Skovhede, GEOGRAF A/S
Greenhough, Jamie skrev:
> Thanks Kenneth. I have just begun using the Maestro API. Thanks again
> for all your work on this.
> Using this API to access the layer properties does sound easier than
> using a layerfactory to generate the LayerDefinition XML.
> So I think I will need to create the VectorLayerDefinition,
> VectorScaleRange, PointTypeStyle, PointSymbolization2DType,
> MarkSymbolType, PointTypeStyleType, and FillType. Then put all these
> pieces together into a LayerDefinition.
> Am I missing something? Do you have any maestro code snippets that
> will jumpstart my dev on this?
> *From:* mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Kenneth
> *Sent:* Friday, November 07, 2008 1:59 AM
> *To:* MapGuide Users Mail List
> *Subject:* Re: [mapguide-users] FeatureSource. PointTypeStyle?
> LineTypeStyle?
> And some providers return the wrong results.
> Rather than using the layerfactory method, have you tried the MaestroAPI:
> Using the MaestroAPI, you can access the "PointTypeStyle" (and all
> other properties),
>  as a class rather than Xml.
> Jackie C. Ng skrev:
> Look at the class definition of the feature source it (the layer) is
> referencing. More specifically, look at the geometry property and see what
> geometry types it supports. This will correspond with what styles you can
> have in your layer.
> - Jackie
> Greenhough, Jamie wrote:
>     I'm trying to programmatically add shape files as a FeatureSource, and
>     then use a .NET layer factory (ported from PHP) to add a LayerDefinition
>     to the MapGuide repository.
>     I can add the shape files and create a MapGuide FeatureSource just
>     great.
>     I'm stuck with how to determine if the FeatureSource contains Line or
>     Point data. Specifically the <PointTypeStyle> and <LineTypeStyle> nodes
>     in the LayerDefinition.xml.
>     Does anyone have experience with this?
>     Thanks!
>     Jamie Greenhough | IT Consultant
>     Sierra Systems
>     ----Notice Regarding Confidentiality----
>     This email, including any and all attachments, (this "Email") is intended
>     only for the party to whom it is addressed and may contain information
>     that is confidential or privileged.  Sierra Systems Group Inc. and its
>     affiliates accept no responsibility for any loss or damage suffered by any
>     person resulting from any unauthorized use of or reliance upon this Email.
>     If you are not the intended recipient, you are hereby notified that any
>     dissemination, copying or other use of this Email is prohibited.  Please
>     notify us of the error in communication by return email and destroy all
>     copies of this Email.  Thank you.
>     _______________________________________________
>     mapguide-users mailing list
>     mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://themapguyde.blogspot.com
> http://www.linkedin.com/in/jackieng
> intended only for the party to whom it is addressed and may contain
> information that is confidential or privileged. Sierra Systems Group
> Inc. and its affiliates accept no responsibility for any loss or
> damage suffered by any person resulting from any unauthorized use of
> or reliance upon this Email. If you are not the intended recipient,
> you are hereby notified that any dissemination, copying or other use
> of this Email is prohibited. Please notify us of the error in
> communication by return email and destroy all copies of this Email.
> Thank you.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081110/6dd41e4d/attachment.html
