[mapguide-users] Fusion custom widget: how to proceed
ataylor
akt at frikshun.com
Sun Nov 9 21:02:23 EST 2008
Did you ever figure out how to get your geometry features to display?
I've ported the draw_line.php code to JSP and am at the same point. The
code executes, I can refresh the map and see the new layer group and layer,
but not the lines or polygons I have drawn.
I can use the schema report tool to verify the shapes actually exist in the
layer.
Not sure how to debug from here.
Any advice would be much appreaciated,
Allen
gingerbbm wrote:
> I'm struggling with this. I think part of the problem is that I've been
> trying to use the redlining example
> (PHPSAMPLES/DIGITIZING_FEATURES/draw_line.php) in the creation of a Fusion
> widget. Not to mention the fact that this is my first time with the
> MapGuide API and I'm not sure conceptually what the steps are to add a
> custom geometry to a map.
> Where I'm at is that the JavaScript behind my DrawPolygon widget is
> calling the PHP I've written (based on the aforementioned
> "draw_line.php"). I assume that the PHP code is OK (it doesn't error) but
> how do I get the map to refresh once the PHP code has executed?
View this message in context: http://www.nabble.com/Fusion-custom-widget%3A-how-to-proceed-tp18614320p20413324.html
