[mapguide-users] feature not visible when drawing line/polygon
ataylor
akt at frikshun.com
Sun Nov 9 17:28:04 EST 2008
Hello all,
I am attempting to get the draw_line ( and draw_polygon ) functions working
in my JSP map viewer.
I have successfully created a temp layer and layer group which is visible on
my map. I programatically created the geometry feature and added that to
the new temp layer ( code threw no errors ).
I can display the new geometry feature using the schema report php tool.
Problem is that while my programmitically created layer group and layer
appears on my rendered map, the geometry features do not.
Does anyone have a suggestion for how to debug this?
I am attaching the JSP I am using to draw my polygon feature as well as the
SDF file generated.
Thanks,
Allen Taylor http://www.nabble.com/file/p20411678/draw_polygon.jsp
draw_polygon.jsp http://www.nabble.com/file/p20411678/TemporaryPolygons.sdf
View this message in context: http://www.nabble.com/feature-not-visible-when-drawing-line-polygon-tp20411678p20411678.html
