[mapguide-users] Importing map on MapGuide
Zac Spitzer
zac.spitzer at gmail.com
Tue Nov 11 08:22:49 EST 2008
which version of mapguide?
On Tue, Nov 11, 2008 at 10:24 PM, Kenneth Skovhede, GEOGRAF A/S <
ks at geograf.dk> wrote:
> Yes, that sounds correct.
> What happens if you preview the FeatureSource ?
> On the map you must enter the extent of the data, is the entered data
> correct?
> Is the layer visible at the current scale?
> Is the layer visible in the map?
> Does the server log reveal any information?
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Carmelo Saffioti skrev:
> Some people told me to use the SDF format... I tried, using MapGuide
> Maestro, to import the exported SDF file. The connection test gives me:
> "Provider reported no errors". After that, I used the imported file to
> create a new Layer. Then, I created a Map, setting up Resource on Layer
> properties equal to the created layer. Finally, I created a Layout, setting
> up Map resource equal to the created map.
> Is it correct?
> The browser displays a blank map... I hope you can help me
> Cheers
> Carmelo
> ----- Original Message -----
> *From:* Kenneth Skovhede, GEOGRAF A/S <ks at geograf.dk>
> *To:* MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
> *Sent:* Tuesday, November 11, 2008 10:25 AM
> *Subject:* Re: [mapguide-users] Importing map on MapGuide
> If you use SHP, it should be straightforward.
> The Maestro user guide is incomplete, but should get you started:
> http://trac.osgeo.org/mapguide/wiki/maestro/UserGuide
> I would recommend installing the Sheboygan sample to see how that works.
> http://mapguide.osgeo.org/download/releases/2.0.x-samples
> Hi everybody,
> I've got a DWG planimetry file from which I'd like create a digital map,
> managed by the MapGuide map server.
> I've converted the DWG file into different formats (dwf, dxf, sdf, shp),
> for importing it in the simplier way.
> How can I do to import and display it on MapGuide? Which steps should I
> follow?
> I tried with MapGuide Maestro, but the application I created seems to do
> not work properly, because the browser stays on loading...
> Cheers
> Carmelo
> mapguide-users mailing listmapguide-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/mapguide-users
Zac Spitzer -
http://zacster.blogspot.com
http://ennoble.dreamhosters.com/mapguide-central/
+61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081112/0c4779e2/attachment.html
