[mapguide-users] Importing map on MapGuide
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Tue Nov 11 06:24:24 EST 2008
Yes, that sounds correct.
What happens if you preview the FeatureSource ?
On the map you must enter the extent of the data, is the entered data
correct?
Is the layer visible at the current scale?
Is the layer visible in the map?
Does the server log reveal any information?
Regards, Kenneth Skovhede, GEOGRAF A/S
Carmelo Saffioti skrev:
> Some people told me to use the SDF format... I tried, using MapGuide
> Maestro, to import the exported SDF file. The connection test gives
> me: "Provider reported no errors". After that, I used the imported
> file to create a new Layer. Then, I created a Map, setting up
> Resource on Layer properties equal to the created layer. Finally, I
> created a Layout, setting up Map resource equal to the created map.
> Is it correct?
> The browser displays a blank map... I hope you can help me
> Cheers
> Carmelo
>     ----- Original Message -----
>     *From:* Kenneth Skovhede, GEOGRAF A/S <mailto:ks at geograf.dk>
>     *To:* MapGuide Users Mail List
>     <mailto:mapguide-users at lists.osgeo.org>
>     *Sent:* Tuesday, November 11, 2008 10:25 AM
>     *Subject:* Re: [mapguide-users] Importing map on MapGuide
>     If you use SHP, it should be straightforward.
>     The Maestro user guide is incomplete, but should get you started:
>     http://trac.osgeo.org/mapguide/wiki/maestro/UserGuide
>     I would recommend installing the Sheboygan sample to see how that
>     works.
>     http://mapguide.osgeo.org/download/releases/2.0.x-samples
>>     Hi everybody,
>>     I've got a DWG planimetry file from which I'd like create a
>>     digital map, managed by the MapGuide map server.
>>     I've converted the DWG file into different formats (dwf, dxf,
>>     sdf, shp), for importing it in the simplier way.
>>     How can I do to import and display it on MapGuide? Which steps
>>     should I follow?
>>     I tried with MapGuide Maestro, but the application I created
>>     seems to do not work properly, because the browser stays on
>>     loading...
>>     Cheers
>>     Carmelo
>>     _______________________________________________
>>     mapguide-users mailing list
>>     http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081111/dec0b9cd/attachment.html
