[mapguide-users] Importing map on MapGuide
Carmelo Saffioti
csaffi at libero.it
Tue Nov 11 06:11:40 EST 2008
Some people told me to use the SDF format... I tried, using MapGuide Maestro, to import the exported SDF file. The connection test gives me: "Provider reported no errors". After that, I used the imported file to create a new Layer. Then, I created a Map, setting up Resource on Layer properties equal to the created layer. Finally, I created a Layout, setting up Map resource equal to the created map.
Is it correct?
The browser displays a blank map... I hope you can help me
Cheers
Carmelo
----- Original Message -----
To: MapGuide Users Mail List
Sent: Tuesday, November 11, 2008 10:25 AM
Subject: Re: [mapguide-users] Importing map on MapGuide
If you use SHP, it should be straightforward.
The Maestro user guide is incomplete, but should get you started:
http://trac.osgeo.org/mapguide/wiki/maestro/UserGuide
I would recommend installing the Sheboygan sample to see how that works.
http://mapguide.osgeo.org/download/releases/2.0.x-samples
Regards, Kenneth Skovhede, GEOGRAF A/S
Carmelo Saffioti skrev:
Hi everybody,
I've got a DWG planimetry file from which I'd like create a digital map, managed by the MapGuide map server.
I've converted the DWG file into different formats (dwf, dxf, sdf, shp), for importing it in the simplier way.
How can I do to import and display it on MapGuide? Which steps should I follow?
I tried with MapGuide Maestro, but the application I created seems to do not work properly, because the browser stays on loading...
Cheers
Carmelo
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081111/29334725/attachment.html
