[mapguide-users] Importing map on MapGuide
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Tue Nov 11 04:25:04 EST 2008
If you use SHP, it should be straightforward.
The Maestro user guide is incomplete, but should get you started:
http://trac.osgeo.org/mapguide/wiki/maestro/UserGuide
I would recommend installing the Sheboygan sample to see how that works.
http://mapguide.osgeo.org/download/releases/2.0.x-samples
Regards, Kenneth Skovhede, GEOGRAF A/S
Carmelo Saffioti skrev:
> Hi everybody,
> I've got a DWG planimetry file from which I'd like create a digital
> map, managed by the MapGuide map server.
> I've converted the DWG file into different formats (dwf, dxf, sdf,
> shp), for importing it in the simplier way.
> How can I do to import and display it on MapGuide? Which steps should
> I follow?
> I tried with MapGuide Maestro, but the application I created seems to
> do not work properly, because the browser stays on loading...
> I hope you can help me
> Cheers
> Carmelo
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081111/00fbb34e/attachment.html
