[mapguide-users] Importing map on MapGuide
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Wed Nov 12 03:45:44 EST 2008
OK, since your data shows, your layer and featuresource are likely correct.
The "Set view to current layers extent" does not work for all data:
http://trac.osgeo.org/mapguide/ticket/609
You need to open your data in another program, and verify that the
extents are correct.
If your layer has "minscale = 0" and "maxscale = 100", you can't see it
in the map even if it is initially marked as visible.
Could you check the server log for any errors:
C:\Program Files\MapGuideOpenSource2.0\Server\Logs\error.log
Could you try to assign a projection on the map? If you have no idea
what the projection is, try "XY-M".
In the question "Is the layer visible in the map", I meant: Is the
"layer is visibile" checked?
Regards, Kenneth Skovhede, GEOGRAF A/S
Carmelo Saffioti skrev:
> < What happens if you preview the FeatureSource ?
> The Layer preview shows me my map successfully
> < On the map you must enter the extent of the data, is the entered
> data correct?
> I don't know. To set it up I clicked on button "Set view to current
> layers extent". How can I do?
> < Is the layer visible at the current scale?
> How can I know that? The Layer previews, as I said, shows me my map
> successfully
> < Is the layer visible in the map?
> The Map preview shows me a blank map. On the left I have got a panel
> named Layers on which I can see the name of my layer, with a checkbox
> near it.
> ----- Original Message -----
> *From:* Kenneth Skovhede, GEOGRAF A/S <mailto:ks at geograf.dk>
> *To:* MapGuide Users Mail List
> <mailto:mapguide-users at lists.osgeo.org>
> *Sent:* Tuesday, November 11, 2008 12:24 PM
> *Subject:* Re: [mapguide-users] Importing map on MapGuide
> Yes, that sounds correct.
> data correct?
> Does the server log reveal any information?
>> Some people told me to use the SDF format... I tried, using
>> MapGuide Maestro, to import the exported SDF file. The connection
>> test gives me: "Provider reported no errors". After that, I used
>> the imported file to create a new Layer. Then, I created a Map,
>> setting up Resource on Layer properties equal to the created
>> layer. Finally, I created a Layout, setting up Map resource equal
>> to the created map.
>> Is it correct?
>> The browser displays a blank map... I hope you can help me
>> Cheers
>> Carmelo
>> *Sent:* Tuesday, November 11, 2008 10:25 AM
>> If you use SHP, it should be straightforward.
>> The Maestro user guide is incomplete, but should get you started:
>> http://trac.osgeo.org/mapguide/wiki/maestro/UserGuide
>> I would recommend installing the Sheboygan sample to see how
>> that works.
>> http://mapguide.osgeo.org/download/releases/2.0.x-samples
>>> Hi everybody,
>>> I've got a DWG planimetry file from which I'd like create a
>>> digital map, managed by the MapGuide map server.
>>> I've converted the DWG file into different formats (dwf,
>>> dxf, sdf, shp), for importing it in the simplier way.
>>> How can I do to import and display it on MapGuide? Which
>>> steps should I follow?
>>> I tried with MapGuide Maestro, but the application I created
>>> seems to do not work properly, because the browser stays on
>>> loading...
>>> Cheers
>>> Carmelo
>>> mapguide-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081112/e9d39cfd/attachment.html
