[mapguide-users] Importing map on MapGuide
Carmelo Saffioti
csaffi at libero.it
Wed Nov 12 04:33:54 EST 2008
< You need to open your data in another program, and verify that the extents are correct.
What program could I use?
< If your layer has "minscale = 0" and "maxscale = 100", you can't see it in the map even if it is initially marked as visible.
Minumum=infinite, Maximum=infinite
If I change to Minimum=1 Maximum=100 the Layer preview is blank
If I change to Minimum=1 Maximum=10000 the Layer preview is blank
If I change to Minimum=1 Maximum=100000 the Layer preview is ok, it displays my map, but the Map preview is still blank
< In the question "Is the layer visible in the map", I meant: Is the "layer is visibile" checked?
It was checked, but unchecking it the Map was still blank
< Could you check the server log for any errors: C:\Program Files\MapGuideOpenSource2.0\Server\Logs\error.log
There are only errors in the past, not at present time
< Could you try to assign a projection on the map? If you have no idea what the projection is, try "XY-M".
I tried. Assigning "Arbitrary X-Y Coordinates (Meter) (XY-M)" the Map is displayed. So, is it a Coordinate system problem? I need to work with GPS coordinates, because I need to trace vehicles movements... how can I do?
----- Original Message -----
To: MapGuide Users Mail List
Sent: Wednesday, November 12, 2008 9:45 AM
Subject: Re: [mapguide-users] Importing map on MapGuide
OK, since your data shows, your layer and featuresource are likely correct.
The "Set view to current layers extent" does not work for all data:
http://trac.osgeo.org/mapguide/ticket/609
Regards, Kenneth Skovhede, GEOGRAF A/S
Carmelo Saffioti skrev:
< What happens if you preview the FeatureSource ?
The Layer preview shows me my map successfully
< On the map you must enter the extent of the data, is the entered data correct?
I don't know. To set it up I clicked on button "Set view to current layers extent". How can I do?
< Is the layer visible at the current scale?
How can I know that? The Layer previews, as I said, shows me my map successfully
< Is the layer visible in the map?
The Map preview shows me a blank map. On the left I have got a panel named Layers on which I can see the name of my layer, with a checkbox near it.
Sent: Tuesday, November 11, 2008 12:24 PM
Yes, that sounds correct.
Does the server log reveal any information?
Some people told me to use the SDF format... I tried, using MapGuide Maestro, to import the exported SDF file. The connection test gives me: "Provider reported no errors". After that, I used the imported file to create a new Layer. Then, I created a Map, setting up Resource on Layer properties equal to the created layer. Finally, I created a Layout, setting up Map resource equal to the created map.
Is it correct?
The browser displays a blank map... I hope you can help me
Cheers
Carmelo
Sent: Tuesday, November 11, 2008 10:25 AM
If you use SHP, it should be straightforward.
The Maestro user guide is incomplete, but should get you started:
http://trac.osgeo.org/mapguide/wiki/maestro/UserGuide
I would recommend installing the Sheboygan sample to see how that works.
http://mapguide.osgeo.org/download/releases/2.0.x-samples
Hi everybody,
I've got a DWG planimetry file from which I'd like create a digital map, managed by the MapGuide map server.
I've converted the DWG file into different formats (dwf, dxf, sdf, shp), for importing it in the simplier way.
How can I do to import and display it on MapGuide? Which steps should I follow?
I tried with MapGuide Maestro, but the application I created seems to do not work properly, because the browser stays on loading...
Cheers
Carmelo
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081112/5bb7e1da/attachment.html
