[mapguide-users] GetFeaturesKml and GetLayerKml
Jason Birch Jason.Birch at nanaimo.ca
Thu Nov 13 05:15:56 EST 2008
Absolutely you can, it's just that the original RFC intended these as
interactive APIs created from the initial GetMapKML rather than
individual layer/feature access APIs.  I don't think there's any problem
with it, but haven't seen a lot of experimentation either...
That would be the approach that I'd take as well if I was going to try
using the build-in functions; DMSG wrote something similar to that for
me that basically reads an existing layer definition, uses a bit of DOM
manipulation to swap out the filter element's text, and uses the
modified layerdefinition in a new map.  GetLayerKML should allow a
similar strategy; please let us know how you make out.
Good luck!
Jason
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of alucas
Sent: Thursday, November 13, 2008 00:23
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] GetFeaturesKml and GetLayerKml
Hi Jason,
Actually, I can use this operations calling directly the agent as well
from
the web extensions API (i.e Java) from the MgKmlService. For my current
project, I need to publish one entire layer and some features from this
layer. For now, publish the layer via MgKmlService::GetLayerKml(...)
works
fine. Otherwise, GetFeaturesKml(...) does not work for me or it does the
same that GetLayerKml.
So, my next step is create a filter for the layer and then call
GetLayerKml
in order to see if it only export the filtered features.
P.D: Sorry for my english.
Thanks.
JasonBirch wrote:
> These functions aren't actually supposed to be called directly be the
> user.
> http://trac.osgeo.org/mapguide/wiki/MapGuideRfc4
> There are quite a few other limitations here, such as being
> session-based (if the user saves in Google Earth, it'll break when the
> session expires), etc.
> I'd personally recommend hand-coding the KML that you emit.  There is
a
> sample app here with source included that shows how to do this:
> http://data.mapguide.com/mapguide/DynamicKml/GoogleEarth.php
> Jason
> From: alucas
> Subject: [mapguide-users] GetFeaturesKml and GetLayerKml
> What is the diference between these methods? How can I get only some
> features from my layer and then export to kml? I suposed that with
> GetFeaturesKml I was able to filter features in a layer...
> mapguide-users mailing list
View this message in context:
http://www.nabble.com/GetFeaturesKml-and-GetLayerKml-tp20459874p20476499
.html
