[mapguide-users] GetFeaturesKml and GetLayerKml
alucas
alucas at srtec.com
Thu Nov 13 07:58:54 EST 2008
Hi Jason,
It seems that with the GetFeaturesKML() method there is no dependency from
the server session. If I generate the .kml with this method the file size is
in my example about 4 MB. So, it seems that the features are in the kml and
not connected vía mapagent and session.
If you want some sample code I can send you how it works.
Regards,
JasonBirch wrote:
> Hi,
> Absolutely you can, it's just that the original RFC intended these as
> interactive APIs created from the initial GetMapKML rather than
> individual layer/feature access APIs. I don't think there's any problem
> with it, but haven't seen a lot of experimentation either...
> That would be the approach that I'd take as well if I was going to try
> using the build-in functions; DMSG wrote something similar to that for
> me that basically reads an existing layer definition, uses a bit of DOM
> manipulation to swap out the filter element's text, and uses the
> modified layerdefinition in a new map. GetLayerKML should allow a
> similar strategy; please let us know how you make out.
> Good luck!
> Jason
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of alucas
> Sent: Thursday, November 13, 2008 00:23
> To: mapguide-users at lists.osgeo.org
> Subject: RE: [mapguide-users] GetFeaturesKml and GetLayerKml
> Hi Jason,
> Actually, I can use this operations calling directly the agent as well
> from
> the web extensions API (i.e Java) from the MgKmlService. For my current
> project, I need to publish one entire layer and some features from this
> layer. For now, publish the layer via MgKmlService::GetLayerKml(...)
> works
> fine. Otherwise, GetFeaturesKml(...) does not work for me or it does the
> same that GetLayerKml.
> So, my next step is create a filter for the layer and then call
> GetLayerKml
> in order to see if it only export the filtered features.
> P.D: Sorry for my english.
> Thanks.
> JasonBirch wrote:
>> These functions aren't actually supposed to be called directly be the
>> user.
>> http://trac.osgeo.org/mapguide/wiki/MapGuideRfc4
>> There are quite a few other limitations here, such as being
>> session-based (if the user saves in Google Earth, it'll break when the
>> session expires), etc.
>> I'd personally recommend hand-coding the KML that you emit. There is
> a
>> sample app here with source included that shows how to do this:
>> http://data.mapguide.com/mapguide/DynamicKml/GoogleEarth.php
>> Jason
>> From: alucas
>> Subject: [mapguide-users] GetFeaturesKml and GetLayerKml
>> What is the diference between these methods? How can I get only some
>> features from my layer and then export to kml? I suposed that with
>> GetFeaturesKml I was able to filter features in a layer...
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://www.nabble.com/GetFeaturesKml-and-GetLayerKml-tp20459874p20476499
> .html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
View this message in context: http://www.nabble.com/GetFeaturesKml-and-GetLayerKml-tp20459874p20480336.html
