[mapguide-users] Modify dynamically a layer
Mauricio Villablanca mgvillablanca at yahoo.com
Sat Nov 15 02:29:12 EST 2008
Yes it is. Get the Llyer definition of your layer then modify it via dom
(since it's an xml file) by adding the <Filter> </Filter> tag.  If you want
to preserve the layer for future use, I suggest you copy the layer
definition  to the session/library reposityory first, edit it then create a
new layer from the modified layer definition.
Finally, add it to the layer collection, save the map and refresh it.
euskalmap wrote:
> Hi,
> We want modify dynamically a layer; for exemple, modify the filter of a
> layer  when the map is loaded;
> Is it possible ?
> What is the method : using an API ?
> Thanks
> Francis MILHAU
> SARL AG-CARTO
> Centre Prouillata
> 10, allée Suzanne Garanx
> 64100 Bayonne
> Tél : 05.59.55.44.62
> Fax : 05.59.55.48.85
> Email : contact at ag-carto.fr
> Site Internet : www.agcarto.fr
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Modify-dynamically-a-layer-tp20419536p20513146.html
