[mapguide-users] Displaying points of given GPS coordinates
ajid1980
ah_jid at yahoo.com
Sat Nov 15 09:15:03 EST 2008
Where The Sample... Can U provide a link.. Thanx..
It Has a Source Code??
Mauricio Villablanca wrote:
> Look at the samples. One of them shows how to dynamically create points of
> interests.
> Carmelo Saffioti wrote:
>> Hi everybody,
>> I successfully imported into MapGuide my planimetry exported as SHP and
>> as SDF. I need to display on the map some GPS points which have a lat/lon
>> coordinate. The map coordinate system is LL84 (WGS84), therefore the
>> coordinate system should be the same for these GPS points and for the
>> map.
>> How can I do to display points with given coordinates on the map? Is
>> there any example or tutorial or other?
>> Thank you in advance
>> Cheers
>> Carmelo
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/Displaying-points-of-given-GPS-coordinates-tp20479019p20515872.html
