[mapguide-users] Displaying points of given GPS coordinates
Mauricio Villablanca
mgvillablanca at yahoo.com
Sat Nov 15 02:20:51 EST 2008
Look at the samples. One of them shows how to dynamically create points of
interests.
Carmelo Saffioti wrote:
> Hi everybody,
> I successfully imported into MapGuide my planimetry exported as SHP and as
> SDF. I need to display on the map some GPS points which have a lat/lon
> coordinate. The map coordinate system is LL84 (WGS84), therefore the
> coordinate system should be the same for these GPS points and for the map.
> How can I do to display points with given coordinates on the map? Is there
> any example or tutorial or other?
> Thank you in advance
> Cheers
> Carmelo
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Displaying-points-of-given-GPS-coordinates-tp20479019p20513108.html
