[mapguide-users] config.xml
Mbonnet
mbonnet at adelior.gfi.fr
Mon Nov 17 03:40:09 EST 2008
Yes i have done it but when i use the getresourcedata function for my oracle
feature source in the mapagent website, it returns an error :
Resource data was not found: config.xml Exception occurred in method
MgTagManager.GetTag at line 372 in file
d:\buildforgeprojects\carrera_nightly\build_32.2\ent\os\server\src\services\resource\TagManager.cpp
thanks
Kenneth Skovhede, GEOGRAF A/S wrote:
> You can open the FeatureSource with Studio, customize columns, and then
> save it.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Mbonnet skrev:
>> When i use the getresourcecontent function in the mapagent website for my
>> feature source it don't have any configurationdoncument property...
>> How can i force to create it ???
>> thanks
>>> The FeatureSource itself has a "ConfigurationDocument" property, could
>>> it have another name?
>>> I believe it is possible to use Oracle without the document, so maybe
>>> you have to set up some mapping to force its creation.
>>> Mbonnet skrev:
>>>> Hi,
>>>> in mapguide 2009 i could find the config.xml file for a oracle database
>>>> featuresource but in mapguide 2009 i could'nt find it with the
>>>> getresourcedata function.
>>>> thanks
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/config.xml-tp20498221p20535585.html
