[mapguide-users] config.xml
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Mon Nov 17 09:07:43 EST 2008
It is possible that the provider is "smart" enough to work without such
a document now.
What do you need it for?
If you want the layout of the data, the DescribeFeatureSource can give
you that.
Regards, Kenneth Skovhede, GEOGRAF A/S
Mbonnet skrev:
> Yes i have done it but when i use the getresourcedata function for my oracle
> feature source in the mapagent website, it returns an error :
> Resource data was not found: config.xml Exception occurred in method
> MgTagManager.GetTag at line 372 in file
> d:\buildforgeprojects\carrera_nightly\build_32.2\ent\os\server\src\services\resource\TagManager.cpp
> thanks
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> You can open the FeatureSource with Studio, customize columns, and then
>> save it.
>> Mbonnet skrev:
>>> When i use the getresourcecontent function in the mapagent website for my
>>> feature source it don't have any configurationdoncument property...
>>> How can i force to create it ???
>>> thanks
>>>> The FeatureSource itself has a "ConfigurationDocument" property, could
>>>> it have another name?
>>>> I believe it is possible to use Oracle without the document, so maybe
>>>> you have to set up some mapping to force its creation.
>>>> Mbonnet skrev:
>>>>> Hi,
>>>>> in mapguide 2009 i could find the config.xml file for a oracle database
>>>>> featuresource but in mapguide 2009 i could'nt find it with the
>>>>> getresourcedata function.
>>>>> thanks
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081117/7e3377e4/attachment.html
