[mapguide-users] config.xml
Mbonnet mbonnet at adelior.gfi.fr
Mon Nov 17 09:16:00 EST 2008
in the code i create new tables, so i want to update my feature source
without using the studio. where can i found a describefeaturesource ???
thanks
Kenneth Skovhede, GEOGRAF A/S wrote:
> It is possible that the provider is "smart" enough to work without such
> a document now.
> What do you need it for?
> If you want the layout of the data, the DescribeFeatureSource can give
> you that.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Mbonnet skrev:
>> Yes i have done it but when i use the getresourcedata function for my
>> oracle
>> feature source in the mapagent website, it returns an error :
>> Resource data was not found: config.xml Exception occurred in method
>> MgTagManager.GetTag at line 372 in file
>> d:\buildforgeprojects\carrera_nightly\build_32.2\ent\os\server\src\services\resource\TagManager.cpp
>> thanks
>>> You can open the FeatureSource with Studio, customize columns, and then
>>> save it.
>>> Mbonnet skrev:
>>>> When i use the getresourcecontent function in the mapagent website for
>>>> my
>>>> feature source it don't have any configurationdoncument property...
>>>> How can i force to create it ???
>>>> thanks
>>>>> The FeatureSource itself has a "ConfigurationDocument" property, could
>>>>> it have another name?
>>>>> I believe it is possible to use Oracle without the document, so maybe
>>>>> you have to set up some mapping to force its creation.
>>>>> Mbonnet skrev:
>>>>>> Hi,
>>>>>> in mapguide 2009 i could find the config.xml file for a oracle
>>>>>> database
>>>>>> featuresource but in mapguide 2009 i could'nt find it with the
>>>>>> getresourcedata function.
>>>>>> thanks
>>>>> _______________________________________________
>>>>> mapguide-users mailing list
>>>>> mapguide-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/config.xml-tp20498221p20540211.html
