[mapguide-users] config.xml
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Tue Nov 18 05:55:20 EST 2008
It can be found here:
http://localhost/mapguide/mapagent/index.html
Under "Feature" -> "DescribeSchema".
There should be an equvalent function in the API, if you create an
MgFeatureService object.
Regards, Kenneth Skovhede, GEOGRAF A/S
Mbonnet skrev:
> in the code i create new tables, so i want to update my feature source
> without using the studio. where can i found a describefeaturesource ???
> thanks
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> It is possible that the provider is "smart" enough to work without such
>> a document now.
>> What do you need it for?
>> If you want the layout of the data, the DescribeFeatureSource can give
>> you that.
>> Mbonnet skrev:
>>> Yes i have done it but when i use the getresourcedata function for my
>>> oracle
>>> feature source in the mapagent website, it returns an error :
>>> Resource data was not found: config.xml Exception occurred in method
>>> MgTagManager.GetTag at line 372 in file
>>> d:\buildforgeprojects\carrera_nightly\build_32.2\ent\os\server\src\services\resource\TagManager.cpp
>>> thanks
>>>> You can open the FeatureSource with Studio, customize columns, and then
>>>> save it.
>>>> Mbonnet skrev:
>>>>> When i use the getresourcecontent function in the mapagent website for
>>>>> my
>>>>> feature source it don't have any configurationdoncument property...
>>>>> How can i force to create it ???
>>>>> thanks
>>>>>> The FeatureSource itself has a "ConfigurationDocument" property, could
>>>>>> it have another name?
>>>>>> I believe it is possible to use Oracle without the document, so maybe
>>>>>> you have to set up some mapping to force its creation.
>>>>>> Mbonnet skrev:
>>>>>>> Hi,
>>>>>>> in mapguide 2009 i could find the config.xml file for a oracle
>>>>>>> database
>>>>>>> featuresource but in mapguide 2009 i could'nt find it with the
>>>>>>> getresourcedata function.
>>>>>>> thanks
>>>>>> _______________________________________________
>>>>>> mapguide-users mailing list
>>>>>> mapguide-users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081118/02e174ce/attachment.html
