[mapguide-users] MGOS2.0.2 - does need some tuning and now ArcSDE ..
Haris Kurtagic haris at sl-king.com
Mon Nov 17 08:28:56 EST 2008
Regarding King.Oracle, can you explain more what is going wrong ?
Latest couple of releases of King.Oracle are slow and there are Oracle client/ King.Oracle build mismatches.
But even slow and memory consuming it should work :)
BTW, this week I will release newer version of King.Oracle with very improved performance (multiple factor in some of my test cases).
Haris
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of djonio
Sent: Monday, November 17, 2008 1:48 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] MGOS2.0.2 - does need some tuning and now ArcSDE ..
Howdy,
By doing one-thing-at-once I have found MrSid seems to work fine, at least
in the short term. Poked and prodded no crashes.
Based upon my config here it appears then King.Oracle is broken. Yes, I am
using the interim fix outlined in
http://www.nabble.com/Could-it-be-MGOS2.0.2---maybe-needs-some-tuning--td20204668.html#a20209315
and others
Soooo, I tried the the ArcSDE provider, again standard MGOS 2.0.2, configs
fine, renders fine(little slow) HOWEVER when I do a selection, 1-x features
it never returns. Alas lost in space …
Anyone?
Do I have to turn everything into an SDF?
r,
dennis
View this message in context: http://www.nabble.com/MGOS2.0.2---does-need-some-tuning-and-now-ArcSDE-..-tp20538805p20538805.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
