[mapguide-users] Creating Streets and info
Zac Spitzer
zac.spitzer at gmail.com
Tue Nov 18 06:29:40 EST 2008
have a look at how the example you looked at is configured
the street layer will expose a tooltip based on the attributes chosen
from the feature source in the tooltip expression
z
On Tue, Nov 18, 2008 at 10:29 PM, Carmelo Saffioti <csaffi at libero.it> wrote:
> Thank you for your answer.
> I'm using Maestro. Ok, I see that the tooltip is definable on the layer with
> Maestro.
> So, to have a tooltip for each street should I have a layer for each street?
> ----- Original Message -----
> From: "Zac Spitzer" <zac.spitzer at gmail.com>
> To: "MapGuide Users Mail List" <mapguide-users at lists.osgeo.org>
> Sent: Tuesday, November 18, 2008 12:15 PM
> Subject: Re: [mapguide-users] Creating Streets and info
>> what tools are you using? studio, maestro?
>> they are called tooltips and they are defined per layer
>> On Tue, Nov 18, 2008 at 10:12 PM, Carmelo Saffioti <csaffi at libero.it>
> wrote:
>> > Hi everybody,
>> > Seeing the MapGuide viewer example I saw that when the mouse cursor is
> over
>> > a street it displays a message with informations about the street. I'd
> like
>> > to make something similar. I need to create streets and infos too. How
> can I
>> > do?
>> > I hope you can help me starting
>> > Cheers
>> > Carmelo
>> > _______________________________________________
>> > mapguide-users mailing list
>> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> Zac Spitzer -
>> http://zacster.blogspot.com
>> http://ennoble.dreamhosters.com/mapguide-central/
>> +61 405 847 168
Zac Spitzer -
+61 405 847 168
