[mapguide-users] Creating Streets and info
Carmelo Saffioti
csaffi at libero.it
Tue Nov 18 08:48:51 EST 2008
Thanks Zac.
You said that the street layer tooltip is based on attributes chosen from
the feature source. Looking with Maestro at the viewer example I see what
you mean. Then now I need to create a feature source with attributes. The
feature source I'm using is a SHP file exported from my DWG planimetry with
Autocad Map. Importing it into MapGuide I can see that it has only 1
attribute: FeatId.
I saw that the viewer example uses a layer called "Parcels", which has many
attributes. I need something similar, because on my planimetry I have many
adiacents blocks, and for each of them I need to show a tooltip with detail
informations (for example: Row number, Block number, Area code).
Have I create this blocks, with their detail informations, on Autocad Map?
I tried importing the Parcel SDF file features source into Autocad Map, and
I see that each block is a poliline. But I don't see any attribute, I don't
know how to...
----- Original Message -----
To: "MapGuide Users Mail List" <mapguide-users at lists.osgeo.org>
Sent: Tuesday, November 18, 2008 12:29 PM
Subject: Re: [mapguide-users] Creating Streets and info
> have a look at how the example you looked at is configured
> the street layer will expose a tooltip based on the attributes chosen
> from the feature source in the tooltip expression
> z
> On Tue, Nov 18, 2008 at 10:29 PM, Carmelo Saffioti <csaffi at libero.it>
wrote:
> > Thank you for your answer.
> > I'm using Maestro. Ok, I see that the tooltip is definable on the layer
with
> > Maestro.
> > So, to have a tooltip for each street should I have a layer for each
street?
> > From: "Zac Spitzer" <zac.spitzer at gmail.com>
> > Sent: Tuesday, November 18, 2008 12:15 PM
> >> what tools are you using? studio, maestro?
> >> they are called tooltips and they are defined per layer
> >> On Tue, Nov 18, 2008 at 10:12 PM, Carmelo Saffioti <csaffi at libero.it>
> > wrote:
> >> > Hi everybody,
> >> > Seeing the MapGuide viewer example I saw that when the mouse cursor
is
> > over
> >> > a street it displays a message with informations about the street.
I'd
> > like
> >> > to make something similar. I need to create streets and infos too.
How
> > can I
> >> > do?
> >> > I hope you can help me starting
> >> > Cheers
> >> > Carmelo
> >> > _______________________________________________
> >> > mapguide-users mailing list
> >> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
> >> Zac Spitzer -
> >> http://zacster.blogspot.com
> >> http://ennoble.dreamhosters.com/mapguide-central/
> >> +61 405 847 168
> Zac Spitzer -
> +61 405 847 168
