[mapguide-users] Creating Streets and info
Berdel, Brian brian.berdel at mcmtrans.com
Tue Nov 18 08:45:18 EST 2008
In autocad map you have to create the object data and attach it to the
features.  Check the help for creating object data.  It is pretty
straight forward once you know what you are doing.
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Carmelo
Saffioti
Sent: Tuesday, November 18, 2008 8:49 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Creating Streets and info
Thanks Zac.
You said that the street layer tooltip is based on attributes chosen
from
the feature source. Looking with Maestro at the viewer example I see
what
you mean. Then now I need to create a feature source with attributes.
The
feature source I'm using is a SHP file exported from my DWG planimetry
with
Autocad Map. Importing it into MapGuide I can see that it has only 1
attribute: FeatId.
I saw that the viewer example uses a layer called "Parcels", which has
many
attributes. I need something similar, because on my planimetry I have
many
adiacents blocks, and for each of them I need to show a tooltip with
detail
informations (for example: Row number, Block number, Area code).
Have I create this blocks, with their detail informations, on Autocad
Map?
I tried importing the Parcel SDF file features source into Autocad Map,
and
I see that each block is a poliline. But I don't see any attribute, I
don't
know how to...
----- Original Message -----
To: "MapGuide Users Mail List" <mapguide-users at lists.osgeo.org>
Sent: Tuesday, November 18, 2008 12:29 PM
> have a look at how the example you looked at is configured
> the street layer will expose a tooltip based on the attributes chosen
> from the feature source in the tooltip expression
> z
> On Tue, Nov 18, 2008 at 10:29 PM, Carmelo Saffioti <csaffi at libero.it>
wrote:
> > Thank you for your answer.
> > I'm using Maestro. Ok, I see that the tooltip is definable on the
layer
with
> > Maestro.
> > So, to have a tooltip for each street should I have a layer for each
street?
> > From: "Zac Spitzer" <zac.spitzer at gmail.com>
> > Sent: Tuesday, November 18, 2008 12:15 PM
> >> what tools are you using? studio, maestro?
> >> they are called tooltips and they are defined per layer
> >> On Tue, Nov 18, 2008 at 10:12 PM, Carmelo Saffioti
> > wrote:
> >> > Hi everybody,
> >> > Seeing the MapGuide viewer example I saw that when the mouse
cursor
is
> > over
> >> > a street it displays a message with informations about the
street.
I'd
> > like
> >> > to make something similar. I need to create streets and infos
too.
How
> > can I
> >> > do?
> >> > I hope you can help me starting
> >> > Cheers
> >> > Carmelo
> >> > _______________________________________________
> >> > mapguide-users mailing list
> >> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
> >> Zac Spitzer -
> >> http://zacster.blogspot.com
> >> http://ennoble.dreamhosters.com/mapguide-central/
> >> +61 405 847 168
> Zac Spitzer -
> +61 405 847 168
