[mapguide-users] Mapguide maps using openlayers
Rodolfo Moreno
rmoreno at voxiva.com
Tue Nov 18 10:26:10 EST 2008
Hi Kenneth,
Here is the javascript code. It's similar to the posted in the wiki
(http://trac.osgeo.org/mapguide/attachment/wiki/CodeSamples/JavaScript/OpenlayersExample/sheboygan.php)
<script type="text/javascript">
var map, map2, layer;
//var url =
"http://demo01.dmsolutions.ca/mapguide/mapagent/mapagent.fcgi";
//you can use this URL when MapGuide OS is installed locally
var url = "http://localhost/mapguide/mapagent/mapagent.fcgi";
var metersPerUnit = 111319.4908; //value returned from mapguide
var inPerUnit = OpenLayers.INCHES_PER_UNIT.m * metersPerUnit;
OpenLayers.INCHES_PER_UNIT["dd"] = inPerUnit;
OpenLayers.INCHES_PER_UNIT["degrees"] = inPerUnit;
OpenLayers.DOTS_PER_INCH = 96;
function init(){
var mapBounds = new
OpenLayers.Bounds(-87.764986990963,43.691398128788,-87.6955215109,43.79752000048);
var fixedScales
=[1000,1930.6977300000001,3727.5937199999998,7196.8567300000004,13894.95494,26826.95795,51794.746789999997,100000];
var mapOptions = {
maxExtent: mapBounds,
scales: fixedScales
map = new OpenLayers.Map( 'map', mapOptions );
//tiled map
var tiledParams = {
mapdefinition:
'Library://Samples/Sheboygan/MapsTiled/Sheboygan.MapDefinition',
basemaplayergroupname: "Base Layer Group",
session: '<%=sessionId%>'
var tiledOptions = {
units: "dd",
singleTile: false
var tiledLayer = new OpenLayers.Layer.MapGuide( "GetTileImage",
url,
tiledParams,
tiledOptions );
map.addLayer(tiledLayer);
//un-tiled versions
var dynamicOverlayOptions = {
buffer: 1,
singleTile: true,
isBaseLayer : false,
visibility : false
var mapImageOptions = {
buffer: 1,
singleTile: true,
isBaseLayer : true
var untiledParams = {
session: '<%=sessionId%>',
mapname: 'Sheboygan'
var dynamicLayer = new OpenLayers.Layer.MapGuide(
"GetDynamicMapOverlayImage",
url,
untiledParams,
dynamicOverlayOptions );
map.addLayer(dynamicLayer);
var mapImageLayer = new OpenLayers.Layer.MapGuide( "GetMapImage",
url,
untiledParams,
mapImageOptions );
map.addLayer(mapImageLayer);
map.zoomToMaxExtent();
map.addControl(new OpenLayers.Control.MousePosition());
map.addControl(new OpenLayers.Control.Scale());
var switcher=new OpenLayers.Control.LayerSwitcher();
map.addControl(switcher);
switcher.maximizeControl();
</script>
The sessionId is returned as parameter to openlayers and the mapname is
hard-coded as 'Sheboygan'
only for the untiled version layer.
Also I have tested it with FF and firebug, I have gotten the same result
(see the image attached).
Regards,
Kenneth Skovhede, GEOGRAF A/S wrote:
> How do you return the map name and sessionId to OpenLayers?
> If you use Firebug (in Firefox), the "Net" tab will show you any errors
> thrown by MapGuide.
> http://getfirebug.com/
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Rodolfo Moreno skrev:
>> Hi all,
>> I have tried to port the wiki sample "display mapguide maps using
>> openlayers" from PHP to .NET without successful.
>> The javascript code is the same of the example, the difference is the
>> SERVER
>> CODE. It's my .NET CODE:
>> public partial class OLViewer : System.Web.UI.Page
>> public String sessionId;
>> protected void Page_Load(object sender, EventArgs e)
>> try
>> // Initialize the web tier
>> Utility utility = new Utility(Request);
>> utility.InitializeWebTier();
>> MgUserInformation userInfo = new
>> MgUserInformation("Anonymous",
>> MgSiteConnection siteCnn = new MgSiteConnection();
>> siteCnn.Open(userInfo);
>> MgSite site = siteCnn.GetSite();
>> sessionId = site.CreateSession();
>> userInfo.SetMgSessionId(sessionId);
>> MgResourceService resourceService =
>> (MgResourceService)siteCnn.CreateService(MgServiceType.ResourceService);
>> MgMappingService mappingService =
>> (MgMappingService)siteCnn.CreateService(MgServiceType.MappingService);
>> MgResourceIdentifier resId = new
>> MgResourceIdentifier("Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition");
>> MgMap map = new MgMap();
>> map.Create(resourceService, resId, "Sheboygan");
>> MgSelection sel = new MgSelection(map);
>> sel.Save(resourceService, "Sheboygan");
>> MgResourceIdentifier mapStateId = new
>> MgResourceIdentifier("Session:" + sessionId + "//" + "Sheboygan." +
>> MgResourceType.Map);
>> map.Save(resourceService, mapStateId);
>> catch (Exception er)
>> Response.Write(er.Message);
>> when I run the sample the Page is shown but not the map. (see attached
>> image).
>> http://n2.nabble.com/file/n1511002/MGusingOL.jpg
>> I don't know what is the error.
>> I'd appreciate so much your suggestions.
>> Rodolfo Moreno
>> CivilEng
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
http://n2.nabble.com/file/n1514643/FirebugTest.jpg
Rodolfo Moreno
CivilEng
View this message in context: http://n2.nabble.com/Mapguide-maps-using-openlayers-tp1511002p1514643.html
