[mapguide-users] Mapguide maps using openlayers
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Tue Nov 18 10:41:12 EST 2008
The Firebug shows that you newer send a request to the MapGuide server.
Is there something missing, or are you never calling the init() function?
Regards, Kenneth Skovhede, GEOGRAF A/S
Rodolfo Moreno skrev:
> Hi Kenneth,
> Here is the javascript code. It's similar to the posted in the wiki
> (http://trac.osgeo.org/mapguide/attachment/wiki/CodeSamples/JavaScript/OpenlayersExample/sheboygan.php)
> <script type="text/javascript">
>         var map, map2, layer;
>         //var url =
> "http://demo01.dmsolutions.ca/mapguide/mapagent/mapagent.fcgi";
>         //you can use this URL when MapGuide OS is installed locally
> 		var url = "http://localhost/mapguide/mapagent/mapagent.fcgi";
>         var metersPerUnit = 111319.4908;  //value returned from mapguide
>         var inPerUnit = OpenLayers.INCHES_PER_UNIT.m * metersPerUnit;
>         OpenLayers.INCHES_PER_UNIT["dd"] = inPerUnit;
>         OpenLayers.INCHES_PER_UNIT["degrees"] = inPerUnit;
>         OpenLayers.DOTS_PER_INCH = 96;
>         function init(){
>      	var mapBounds = new
> OpenLayers.Bounds(-87.764986990963,43.691398128788,-87.6955215109,43.79752000048);
> 	var fixedScales
> =[1000,1930.6977300000001,3727.5937199999998,7196.8567300000004,13894.95494,26826.95795,51794.746789999997,100000];
>             var mapOptions = {
>                 maxExtent: mapBounds,
>                 scales: fixedScales
>             map = new OpenLayers.Map( 'map', mapOptions );
> 	        //tiled map
>           var tiledParams = {
>               mapdefinition:
> 'Library://Samples/Sheboygan/MapsTiled/Sheboygan.MapDefinition',
>               basemaplayergroupname: "Base Layer Group",
> 	 session: '<%=sessionId%>'
>           var tiledOptions = {
>               units: "dd",
>               singleTile: false
>           var tiledLayer = new OpenLayers.Layer.MapGuide( "GetTileImage",
> 				url,
> 				tiledParams,
> 				tiledOptions );
>           map.addLayer(tiledLayer);
>          //un-tiled versions
>          var dynamicOverlayOptions = {
>               buffer: 1,
>               singleTile: true,
> 	  isBaseLayer : false,
> 	  visibility : false
>          var mapImageOptions = {
>               buffer: 1,
>               singleTile: true,
> 	 isBaseLayer : true
>         var untiledParams = {
> 	session: '<%=sessionId%>',
>              mapname: 'Sheboygan'
>         var dynamicLayer = new OpenLayers.Layer.MapGuide(
> "GetDynamicMapOverlayImage",
> 	url,
> 	untiledParams,
> 	dynamicOverlayOptions );
>         map.addLayer(dynamicLayer);
>         var mapImageLayer = new OpenLayers.Layer.MapGuide( "GetMapImage",
> 	url,
> 	untiledParams,
> 	mapImageOptions );
>         map.addLayer(mapImageLayer);
>         map.zoomToMaxExtent();
>         map.addControl(new OpenLayers.Control.MousePosition());
>         map.addControl(new OpenLayers.Control.Scale());
>         var switcher=new OpenLayers.Control.LayerSwitcher();
>         map.addControl(switcher);
>         switcher.maximizeControl();
>     </script>
> The sessionId is returned as parameter to openlayers and the mapname is
> hard-coded as 'Sheboygan'
> only for the untiled version layer.
> Also I have tested it with FF and firebug, I have gotten the same result
> (see the image attached).
> Regards,
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> How do you return the map name and sessionId to OpenLayers?
>> If you use Firebug (in Firefox), the "Net" tab will show you any errors
>> thrown by MapGuide.
>> http://getfirebug.com/
>>> Hi all,
>>> I have tried to port the wiki sample "display mapguide maps using
>>> openlayers" from PHP to .NET without successful.
>>> The javascript code is the same of the example, the difference is the
>>> SERVER
>>> CODE. It's my .NET CODE:
>>> public partial class OLViewer : System.Web.UI.Page
>>>     public String sessionId;
>>>     protected void Page_Load(object sender, EventArgs e)
>>>         try
>>>             // Initialize the web tier
>>>             Utility utility = new Utility(Request);
>>>             utility.InitializeWebTier();
>>>             MgUserInformation userInfo = new
>>> MgUserInformation("Anonymous",
>>>             MgSiteConnection siteCnn = new MgSiteConnection();
>>>             siteCnn.Open(userInfo);
>>>             MgSite site = siteCnn.GetSite();
>>>             sessionId = site.CreateSession();
>>>             userInfo.SetMgSessionId(sessionId);
>>>             MgResourceService resourceService =
>>> (MgResourceService)siteCnn.CreateService(MgServiceType.ResourceService);
>>>             MgMappingService mappingService =
>>> (MgMappingService)siteCnn.CreateService(MgServiceType.MappingService);
>>>             MgResourceIdentifier resId = new
>>> MgResourceIdentifier("Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition");
>>>             MgMap map = new MgMap();
>>>             map.Create(resourceService, resId, "Sheboygan");
>>>             MgSelection sel = new MgSelection(map);
>>>             sel.Save(resourceService, "Sheboygan");
>>>             MgResourceIdentifier mapStateId = new
>>> MgResourceIdentifier("Session:" + sessionId + "//" + "Sheboygan." +
>>> MgResourceType.Map);
>>>             map.Save(resourceService, mapStateId);
>>>         catch (Exception er)
>>>             Response.Write(er.Message);
>>> when I run the sample the Page is shown but not the map. (see attached
>>> image).
>>> http://n2.nabble.com/file/n1511002/MGusingOL.jpg
>>> I don't know what is the error.
>>> I'd appreciate so much your suggestions.
>>> Rodolfo Moreno
>>> CivilEng
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://n2.nabble.com/file/n1514643/FirebugTest.jpg
> Rodolfo Moreno
> CivilEng
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081118/a8911167/attachment.html
