[mapguide-users] Routine Road
Zac Spitzer zac.spitzer at gmail.com
Tue Nov 18 20:04:05 EST 2008
rather than using mapgudie open source per se, you could use mapguide to provide
the mapping and then overlay a layer which contains the routing
there are a number of examples out there which demonstrate using
openlayers and pgRouting
http://pgrouting.postlbs.org/wiki/pgRoutingDemo has some
as fusion is based on openlayers it would probably be your best bet
z
On Wed, Nov 19, 2008 at 11:38 AM, ajid1980 <ah_jid at yahoo.com> wrote:
> PgRouting can use on Mapguide Open SOurce?? Have u done before?? So anyone
> have a solution,method, technique.. plz help me.. Thanx
> hayashi-3 wrote:
>> Hi.
>> ajid1980
>> You should use pgRouting.
>> | I need ur help guyz.. anyone have a idea.. i wanna make a road routine..
>> so
>> | any idea about open source routine??.. now i using mapguide open
>> source..
>> | Thanx
>> | I hope we can share any idea..
>> | View this message in context:
>> http://www.nabble.com/Routine-Road-tp20552214p20552214.html
>> | Sent from the MapGuide Users mailing list archive at Nabble.com.
>> | _______________________________________________
>> | mapguide-users mailing list
>> | mapguide-users at lists.osgeo.org
>> | http://lists.osgeo.org/mailman/listinfo/mapguide-users
> View this message in context: http://www.nabble.com/Routine-Road-tp20552214p20571660.html
Zac Spitzer -
http://zacster.blogspot.com
http://ennoble.dreamhosters.com/mapguide-central/
+61 405 847 168
