[mapguide-users] Problem connecting to ArcSDE9.2
Jack Lee
jack.lee at autodesk.com
Tue Nov 18 21:41:06 EST 2008
Hi Steve,
Did you have sde.dll/sg.dll/pe.dll in your path?
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Steve G
Sent: Tuesday, November 18, 2008 7:21 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Problem connecting to ArcSDE9.2
I am currently using OSGeo.ArcSDE.3.3 FDO and trying to connect to an
ArcSDE9.2 database using Maestro. When I try to set up a new data
connection and use the "Test Connection" button, I get the following error
message:
The remote server returned an error: (559) MgFdoException.:
An exception occurred in FDO component.
FDO Provider entry point function 'CreateConnection' returned NULL.
Exception occurred in method MgFdoConnectionManager.Open at line 262 in file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\common\manager\FdoConnectionManager.cpp
I have checked the dlls and they all seem to be in the correct folder
(Server\Bin\FDO). Does anyone have any suggestions of what the problem and
solution might be?
Thanks,
Steve
View this message in context: http://www.nabble.com/Problem-connecting-to-ArcSDE9.2-tp20571485p20571485.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
