[mapguide-users] Problem connecting to ArcSDE9.2
Crispin_at_1Spatial crispin.hoult at 1spatial.com
Wed Nov 19 12:54:35 EST 2008
We have seen issues where the DB underlying the ArcSDE is Oracle and the
geometry is SDO_GEOM.  Other combinations are pretty much reliable.  Is this
your ArcSDE server set-up?  As it all goes through the SDE DLLs it shouldn't
matter.  The other thing is to get the SDE admin to confirm the instance
with 'sdemon' and you *cannot* connect to the server with an IP address - it
must be a resolvable name.
Steve G wrote:
> Yes, I have all three of those (copied from C:\Program Files\ArcGIS\Bin).
> I
> also have ArcSDEMessage.dll, ArcSDEProvider.dll, ArcSDEProvider91.dll and
> ArcSDEProvider92.dll in the same path.  I even updated these to the latest
> files from the FDO webpage but still got the same errors.
> Are there any other updates that I need to make?  It seems to me that the
> error message relates to the FDO.
> Thanks,
> Steve
> Jack Lee-3 wrote:
>> Hi Steve,
>> Did you have sde.dll/sg.dll/pe.dll in your path?
> http://www.nabble.com/Problem-connecting-to-ArcSDE9.2-tp20571485p20585130.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/Problem-connecting-to-ArcSDE9.2-tp1516857p1519938.html
