[mapguide-users] Problem connecting to ArcSDE9.2
Steve G
steve.golden at morganhill.ca.gov
Wed Nov 19 13:07:46 EST 2008
The database is SQL...I am sorry, I should have put that in my original post.
I am going to verify all of the connection properties (I previously tried
different combinations of server, database, and instance).
Server - What do you mean by a resolvable name? Can I use the same server
name as I use in the spatial database connection properties in my ESRI
products? (the server name is currently: pw2000server)
Thanks again,
Steve
Crispin @ 1Spatial wrote:
> We have seen issues where the DB underlying the ArcSDE is Oracle and the
> geometry is SDO_GEOM. Other combinations are pretty much reliable. Is
> this
> your ArcSDE server set-up? As it all goes through the SDE DLLs it
> shouldn't
> matter. The other thing is to get the SDE admin to confirm the instance
> with 'sdemon' and you *cannot* connect to the server with an IP address -
> it
> must be a resolvable name.
View this message in context: http://www.nabble.com/Problem-connecting-to-ArcSDE9.2-tp20571485p20585760.html
