[mapguide-users] Problem connecting to ArcSDE9.2
Steve G steve.golden at morganhill.ca.gov
Wed Nov 19 20:15:30 EST 2008
I have the file "msvcr71.dll" located here "C:\Program Files\ArcGIS\Bin".  Is
that dll supposed to be copied over to C:\Program
Files\MapGuideOpenSource2.0\Server\Bin\FDO?
What do you mean by "does depend show any missing dll on sde.dll?
Sorry for my elementary questions...I am more of a GIS user than a
developer, but trying to learn as I go.
Thanks,
Steve
Jack Lee-3 wrote:
> Hi,
> Are you missing a crt library like msvcr71.dll?
> Does depends show any missing dll on sde.dll?
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of
> Crispin_at_1Spatial
> Sent: Wednesday, November 19, 2008 12:55 PM
> To: mapguide-users at lists.osgeo.org
> Subject: RE: [mapguide-users] Problem connecting to ArcSDE9.2
> We have seen issues where the DB underlying the ArcSDE is Oracle and the
> geometry is SDO_GEOM.  Other combinations are pretty much reliable.  Is
> this
> your ArcSDE server set-up?  As it all goes through the SDE DLLs it
> shouldn't
> matter.  The other thing is to get the SDE admin to confirm the instance
> with 'sdemon' and you *cannot* connect to the server with an IP address -
> it
> must be a resolvable name.
> Steve G wrote:
>> Yes, I have all three of those (copied from C:\Program Files\ArcGIS\Bin).
>> I
>> also have ArcSDEMessage.dll, ArcSDEProvider.dll, ArcSDEProvider91.dll and
>> ArcSDEProvider92.dll in the same path.  I even updated these to the
>> latest
>> files from the FDO webpage but still got the same errors.
>> Are there any other updates that I need to make?  It seems to me that the
>> error message relates to the FDO.
>> Thanks,
>> Steve
>> Jack Lee-3 wrote:
>>> Hi Steve,
>>> Did you have sde.dll/sg.dll/pe.dll in your path?
>> View this message in context:
>> http://www.nabble.com/Problem-connecting-to-ArcSDE9.2-tp20571485p20585130.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://n2.nabble.com/Problem-connecting-to-ArcSDE9.2-tp1516857p1519938.html
View this message in context: http://www.nabble.com/Problem-connecting-to-ArcSDE9.2-tp20571485p20593216.html
