[mapguide-users] Sample application Problem
padmini godavarthi godavarthi.padmini at gmail.com
Thu Nov 20 05:38:01 EST 2008
Hi
Thanks for ur reply.
i changed the configuration file path given by u.
and while running the application i got an error that
Server Error in '/' Application.
The resource cannot be found.
Description: HTTP 404. The resource you are looking for (or one of its
dependencies) could have been removed, had its name changed, or is
temporarily unavailable.  Please review the following URL and make sure that
it is spelled correctly.
Requested URL: /mapviewernet/ajaxviewer.aspx
Version Information: Microsoft .NET Framework Version:2.0.50727.832; ASP.NET
Plz help me.
Regards,
Padmini
zspitzer wrote:
>>  Configuration file "C:\Program
>> Files\MapGuideOpenSource2.0\WebServerExtensions\www\dotnetviewersample\dotnetviewersample\../webconfig.ini"
>> cannot be found or cannot be opened.
> looking at that url, you have installed the sample wrong
> should be
> WebServerExtensions\www\dotnetviewersample\../webconfig.ini
> z
> Zac Spitzer -
> http://zacster.blogspot.com
> http://ennoble.dreamhosters.com/mapguide-central/
> +61 405 847 168
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Sample-application-Problem-tp20576129p20598557.html
