[mapguide-users] Sample application Problem
Zac Spitzer zac.spitzer at gmail.com
Thu Nov 20 06:00:24 EST 2008
I'm happy to help, but can firstly have another look at the error message,
the folders involved and your IIS configuration and try to work it out yourself?
On Thu, Nov 20, 2008 at 9:38 PM, padmini godavarthi
<godavarthi.padmini at gmail.com> wrote:
> Hi
> Thanks for ur reply.
> i changed the configuration file path given by u.
> and while running the application i got an error that
> Server Error in '/' Application.
> The resource cannot be found.
> Description: HTTP 404. The resource you are looking for (or one of its
> dependencies) could have been removed, had its name changed, or is
> temporarily unavailable.  Please review the following URL and make sure that
> it is spelled correctly.
> Requested URL: /mapviewernet/ajaxviewer.aspx
> Version Information: Microsoft .NET Framework Version:2.0.50727.832; ASP.NET
> Plz help me.
> Regards,
> Padmini
> zspitzer wrote:
>>>  Configuration file "C:\Program
>>> Files\MapGuideOpenSource2.0\WebServerExtensions\www\dotnetviewersample\dotnetviewersample\../webconfig.ini"
>>> cannot be found or cannot be opened.
>> looking at that url, you have installed the sample wrong
>> should be
>> WebServerExtensions\www\dotnetviewersample\../webconfig.ini
>> z
>> Zac Spitzer -
>> http://zacster.blogspot.com
>> http://ennoble.dreamhosters.com/mapguide-central/
>> +61 405 847 168
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> View this message in context: http://www.nabble.com/Sample-application-Problem-tp20576129p20598557.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
Zac Spitzer -
+61 405 847 168
