[mapguide-users] Sample application Problem
padmini godavarthi godavarthi.padmini at gmail.com
Thu Nov 20 06:10:06 EST 2008
Thanks for u r reply.
i think the problem might be with sample data given in the sample
application.
String webLayout =
"Library://Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout";
and i changed this in to
String webLayout = "Library://Example/Maplayout.WebLayout";
but it gives the same error .i didn't get any solution for that.
If u tell the answer it will be more helpful to me
  My Configuration is
.net 2005
IIS 5.1
 Mapguide opensource 2.0 ( with IIS Configuration + .Net language)
Thanks and Regards,
Padmini
zspitzer wrote:
> I'm happy to help, but can firstly have another look at the error message,
> the folders involved and your IIS configuration and try to work it out
> yourself?
> On Thu, Nov 20, 2008 at 9:38 PM, padmini godavarthi
> <godavarthi.padmini at gmail.com> wrote:
>> Hi
>> Thanks for ur reply.
>> i changed the configuration file path given by u.
>> and while running the application i got an error that
>> Server Error in '/' Application.
>> The resource cannot be found.
>> Description: HTTP 404. The resource you are looking for (or one of its
>> dependencies) could have been removed, had its name changed, or is
>> temporarily unavailable.  Please review the following URL and make sure
>> that
>> it is spelled correctly.
>> Requested URL: /mapviewernet/ajaxviewer.aspx
>> Version Information: Microsoft .NET Framework Version:2.0.50727.832;
>> ASP.NET
>> Plz help me.
>> Regards,
>> Padmini
>> zspitzer wrote:
>>>>  Configuration file "C:\Program
>>>> Files\MapGuideOpenSource2.0\WebServerExtensions\www\dotnetviewersample\dotnetviewersample\../webconfig.ini"
>>>> cannot be found or cannot be opened.
>>> looking at that url, you have installed the sample wrong
>>> should be
>>> WebServerExtensions\www\dotnetviewersample\../webconfig.ini
>>> z
>>> Zac Spitzer -
>>> http://zacster.blogspot.com
>>> http://ennoble.dreamhosters.com/mapguide-central/
>>> +61 405 847 168
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> View this message in context:
>> http://www.nabble.com/Sample-application-Problem-tp20576129p20598557.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
> Zac Spitzer -
> +61 405 847 168
View this message in context: http://www.nabble.com/Sample-application-Problem-tp20576129p20599024.html
