[mapguide-users] Installation mapguide 64bits
Zac Spitzer
zac.spitzer at gmail.com
Thu Nov 20 07:09:18 EST 2008
based on what i'm seeing going on via trac, 2.1 might support 64-bit :)
2.0.x definitely doesn't work, the wow-something (32?) support might work tho
z
On Thu, Nov 20, 2008 at 11:02 PM, gingerbbm <stuart.jones at jacobs.com> wrote:
> I've installed on Windows Server 2003 64-bit and it certainly doesn't seem to
> work. When I try the functionality in the PHP sample I end up with "Service
> Unavailable" and a bunch of messages like this in the event viewer:
> "A process serving application pool 'MapGuide' terminated unexpectedly. The
> process id was '4056'. The process exit code was '0xe06d7363'."
> And ultimately:
> "Application pool 'MapGuide' is being automatically disabled due to a series
> of failures in the process(es) serving that application pool."
> I'm using MapGuide Enterprise 2009 but I assume the same goes for MGOS.
> Does anyone have any information on this?
> Thanks
> Stuart
> View this message in context: http://n2.nabble.com/Installation-mapguide-64bits-tp1365405p1556838.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com
http://ennoble.dreamhosters.com/mapguide-central/
+61 405 847 168
