[mapguide-users] New King.Oracle 0.8 - improved performance
Nick Adams
nick.adams at 1spatial.com
Fri Nov 21 06:20:46 EST 2008
Hi Harris,
I've tried:
- Oracle 10.2 instant client
- Oracle 11g client
Both give the same:
Attempted to read or write protected memory... error.
I can also concur with FISHeR1: 0.8.4 gives an Unclassified Exception when
rendering a layer in MGOS 2.02, using the instant client.
I'm not 100% certain, but from recollection 0.8.2 was the last version I saw
working in MGOS.
Nick
haris kurtagic wrote:
> Which Oracle client and which version are you using ?
> Haris
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Nick Adams
> Sent: Thursday, November 20, 2008 5:04 PM
> To: mapguide-users at lists.osgeo.org
> Subject: RE: [mapguide-users] New King.Oracle 0.8 - improved performance
> 0.8.4 is giving the same error:
> Attempted to read or write protected memory. This is often an indication
> that other memory is corrupt.
> Nick
> Nick Adams wrote:
>> Ok. I've tried 0.8.3 and I'm now getting:
> indication
>> Nick
>>> I posted 0.8.3 which should fix first problem.
>>> Regarding SDO_FILTER If I remember correcly that is problem with 9.1
>>> provider works in 9.2 ? ).
>>> I don't have 9 versions available to test but if I look at docs and
> you
>>> try it perhaps we can fix it without me trying it.
>>> Haris
> Adams
>>> Sent: Thursday, November 20, 2008 3:55 PM
> performance
>>> - I have been using OracleSchema and it was set to the same as the
>>> username
>>> - Previously I was using 0.7.4.
>>> Unfortunately this didn't work. Then I was getting the error:
>>> ORA-29900: operator binding does not exist ORA-06553: PLS-306:
> wrong
>>> number or types of arguments in call to 'SDO_FILTER'
>>> This I understand to be down to the fact that SDO_FILTER requires 3
>>> arguments in 9i where-as the third one is optional in 10g. I was
> hoping
>>> 0.8.x might solve this.
>>> Nick
>>>> I am looking at code and I have two questions :
>>>> - are you using connection property OracleSchema, and value is same
> as
>>>> UserName ?
>>>> - this has worked for you before release 0.8.2 ?
>>>> Haris
>>> Adams
>>>> Sent: Thursday, November 20, 2008 2:57 PM
>>>> Subject: Re: [mapguide-users] New King.Oracle 0.8 - improved
>>> performance
>>>> Hi Haris,
>>>> I've just downloaded version 0.82 a tried it.
>>>> The problem I'm working on is using the King Oracle provider with
> .Net
>>>> to
>>>> connect to a 9i oracle database.
>>>> The query I'm making is:
>>>> SHAPE ENVELOPEINTERSECTS GeomFromText('POLYGON ((325400 701400,
> 325600
>>>> 701400, 325600 701600, 325400 701600, 325400 701400))')
>>>> The current error it's giving me when I try this is:
>>>> ORA-00904: "C"."SDO_INDEX_OWNER": invalid identifier
>>>> Any suggestions would be appreciated.
>>>> Nick
>>>>> Hi,
>>>>> I have released new version of King.Oracle provider 0.8.
>>>>> It is much faster than previous releases. Lot of code is changed.
>>>>> King.Oracle passed my UniTests but it has to be tested more so your
>>>>> feedback is appreciated.
>>>>> List of changes:
>>>>> Improved performance - very significant improvement
>>>>> Support for SelectAggregate
>>>>> FDO schema creation is now faster , especially when
>>>> OracleScema=UserName
>>>>> Reintroduced schema caching
>>>>> Full Unicode support
>>>>> Using OCI interface
>>>>> You can get it here: www.sl-king.com/fdooracle
>>>>> Haris
>>>>> _______________________________________________
>>>>> mapguide-users mailing list
>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>> View this message in context:
> http://www.nabble.com/New-King.Oracle-0.8---improved-performance-tp20580
>>>> 002p20601567.html
>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> 002p20602909.html
> 002p20604513.html
View this message in context: http://www.nabble.com/New-King.Oracle-0.8---improved-performance-tp20580002p20619229.html
