[mapguide-users] New King.Oracle 0.8 - improved performance
djonio
djonio at miami-airport.com
Fri Nov 21 08:11:33 EST 2008
Haris, et.al,
I think this error one was from the 8.5 test I did first thing this AM.
2008-11-21T06:20:54> Autodesk MapGuide Studio v2.0.2.3402 10.14.12.190
Administrator
Error: An exception occurred in FDO component.
Item GISMIA~FCLTY3000_10~GEOMETRY is already in this named
collection.
StackTrace:
- MgFeatureServiceHandler.ProcessOperation line 83 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
- MgOpDescribeSchemaAsXml.Execute line 105 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\feature\OpDescribeSchemaAsXml.cpp
- MgServerDescribeSchema.DescribeSchemaAsXml line 607 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\feature\ServerDescribeSchema.cpp
- MgServerDescribeSchema.DescribeSchema line 564 file
- MgServerDescribeSchema.ExecuteDescribeSchema line 176 file
Item GISMIA~FCLTY3000_10~GEOMETRY is already in this named collection.
The following are just a few of the errors while doing the 8.5 logging
dll's ....
StackTrace:
- MgMappingUtil.StylizeLayers line 786 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\mapping\MappingUtil.cpp
Failed to stylize layer: LayerDefinition3
An unclassified exception occurred.
<2008-11-21T07:43:22> Fusion Viewer 10.14.12.190 Administrator
Error: Failed to stylize layer: LayerDefinition3
StackTrace:
<2008-11-21T07:45:02> Fusion Viewer 10.14.12.190 Administrator
Error: An unclassified exception occurred.
StackTrace:
- MgOpGetIdentityProperties.Execute line 113 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\feature\OpGetIdentityProperties.cpp
- MgServerDescribeSchema.GetIdentityProperties line 1715 file
There seems to be some issues when changing from one table(class) to another
during Layer Create/Edit. This is when I started to get the
"Unclassified Exception" pop-up in MG Studio 2009.
Server did not crash this time!
When I selected a table of just 2003's NOTHING rendered in preview. Once I
added the layer to a map the polygons rendered but I could not "select" any.
Something feels not right here.
r,
dennis
http://www.nabble.com/file/p20620735/KingOra.log KingOra.log
View this message in context: http://www.nabble.com/New-King.Oracle-0.8---improved-performance-tp20580002p20620735.html
