[mapguide-users] New King.Oracle 0.8 - improved performance
Haris Kurtagic haris at sl-king.com
Fri Nov 21 09:24:19 EST 2008
That error in describe schema looks llike provider would try to generate
two classes with same name.
I checked once more but in provider there is code test for such
duplicate class names and will prevent this to happen.
Can you try with Fdo2Fdo and new provider files ( just copy into Fdo2Fdo
) and try to create connection and read schema/data.
Haris
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of djonio
Sent: Friday, November 21, 2008 2:12 PM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] New King.Oracle 0.8 - improved performance
Haris, et.al,
 I think this error one was from the 8.5 test I did first thing this AM.
 2008-11-21T06:20:54> 	Autodesk MapGuide Studio v2.0.2.3402
10.14.12.190
Administrator
 Error: An exception occurred in FDO component.
        Item GISMIA~FCLTY3000_10~GEOMETRY is already in this named
collection.
 StackTrace:
  - MgFeatureServiceHandler.ProcessOperation line 83 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services
\feature\FeatureServiceHandler.cpp
  - MgOpDescribeSchemaAsXml.Execute line 105 file
\feature\OpDescribeSchemaAsXml.cpp
  - MgServerDescribeSchema.DescribeSchemaAsXml line 607 file
\feature\ServerDescribeSchema.cpp
  - MgServerDescribeSchema.DescribeSchema line 564 file
  - MgServerDescribeSchema.ExecuteDescribeSchema line 176 file
Item GISMIA~FCLTY3000_10~GEOMETRY is already in this named collection.
 The following are just a few of the errors while doing the 8.5 logging
dll's ....
 StackTrace:
  - MgMappingUtil.StylizeLayers line 786 file
\mapping\MappingUtil.cpp
Failed to stylize layer: LayerDefinition3
An unclassified exception occurred.
<2008-11-21T07:43:22> 	Fusion Viewer	10.14.12.190	Administrator
 Error: Failed to stylize layer: LayerDefinition3
 StackTrace:
<2008-11-21T07:45:02> 	Fusion Viewer	10.14.12.190	Administrator
 Error: An unclassified exception occurred.
 StackTrace:
  - MgOpGetIdentityProperties.Execute line 113 file
\feature\OpGetIdentityProperties.cpp
  - MgServerDescribeSchema.GetIdentityProperties line 1715 file
There seems to be some issues when changing from one table(class) to
another
during Layer Create/Edit. This is when I started to get the
"Unclassified Exception" pop-up in MG Studio 2009.
Server did not crash this time!
When I selected a table of just 2003's NOTHING rendered in preview. Once
I
added the layer to a map the polygons rendered but I could not "select"
any.
Something feels not right here.
r,
dennis
http://www.nabble.com/file/p20620735/KingOra.log KingOra.log
View this message in context:
http://www.nabble.com/New-King.Oracle-0.8---improved-performance-tp20580
002p20620735.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
