[mapguide-users] Dotnet viewer sample application problem
stoff
mail at effing.org
Sat Nov 22 05:00:54 EST 2008
Hi padmini,
the error concerning the path of you webconfig.ini is strange. Have you
installed http://mapguide.osgeo.org/download/releases/2.0.2 the windows
binaries? You have to do this and you must import the sheboygan example
package.
You must realize that the dotnetviewersample is not really state-of-the-art
asp.net code. so it works like old asp coding stuff
(http://en.wikipedia.org/wiki/Active_Server_Pages). So it is not debuggable
within the visual studio. Please read
http://www.nabble.com/Create-a-Visual-Studio-2008-Solution-of-dotnetviewersample-to18235849.html#a18235849
this thread .
So it is still a task to develop a dotnetviewersample solution which
contains asp.net compatible coding...
In my project we are working on some parts of the viewer application in real
asp.net code but ... it is remittance work.
Good luck,
stoff
padmini godavarthi wrote:
> Hi,
> Thanks for ur reply .
> I have downloaded the dotnetviewersample.zip from the url
> http://mapguide.osgeo.org/download/releases/2.0.x-samples
> and unzipped in to
> C:\Program
> Files\MapGuideOpenSource2.0\WebServerExtensions\www
> and i copied bin folder and webconfig.ini from mapviewernet application
> and pasted in to dotnetviewersample application
> i have created one virtual directory in IIS (named as dotnetviewersample)
> and openend this application from .Net 2005 .
> While setting the ajaxviewersample.aspx as start page and opened in the
> browser
> it gives an error that
> Configuration file "C:\Program
> Files\MapGuideOpenSource2.0\WebServerExtensions\www\dotnetviewersample\dotnetviewersample\../webconfig.ini"
> cannot be found or cannot be opened.
> My Doubt is that
> 1) How this dotnetviewersample application works?
> 2) How to debug this application?
> 3) What will be the output
> Can u plz tell me briefly?
> if u know the error plz help me.
View this message in context: http://www.nabble.com/Dotnet-viewer-sample-application-problem-tp20480441p20634850.html
