[mapguide-users] Dotnet viewer sample application problem
padmini godavarthi
godavarthi.padmini at gmail.com
Sun Nov 23 20:44:32 EST 2008
Hi ,
Thanks for u r reply.
I have downloaded and installed the Mapguide opensource 2.0 (Windows
Installer)
I choosed it for Mapguide opensource 2.0 (with IIS Configuration + .Net )
Now i have to create one .Net 2005 application for viewing the map.for this
purpose i downloaded the dotnetviewer sample application . i down loaded the
sheboygan example package and kept it in
C:\programfiles\Mapguideopensource2.0\server\packages.
But iam unabble to run the application.It given some errors
plz help me so it will be helpful to me
Regards,
Padmini.
stoff wrote:
> Hi padmini,
> the error concerning the path of you webconfig.ini is strange. Have you
> installed http://mapguide.osgeo.org/download/releases/2.0.2 the windows
> binaries? You have to do this and you must import the sheboygan example
> package.
> You must realize that the dotnetviewersample is not really
> state-of-the-art asp.net code. so it works like old asp coding stuff
> (http://en.wikipedia.org/wiki/Active_Server_Pages). So it is not
> debuggable within the visual studio. Please read
> http://www.nabble.com/Create-a-Visual-Studio-2008-Solution-of-dotnetviewersample-to18235849.html#a18235849
> this thread .
> So it is still a task to develop a dotnetviewersample solution which
> contains asp.net compatible coding...
> In my project we are working on some parts of the viewer application in
> real asp.net code but ... it is remittance work.
> Good luck,
> stoff
> padmini godavarthi wrote:
>> Hi,
>> Thanks for ur reply .
>> I have downloaded the dotnetviewersample.zip from the url
>> http://mapguide.osgeo.org/download/releases/2.0.x-samples
>> and unzipped in to
>> C:\Program
>> Files\MapGuideOpenSource2.0\WebServerExtensions\www
>> and i copied bin folder and webconfig.ini from mapviewernet application
>> and pasted in to dotnetviewersample application
>> i have created one virtual directory in IIS (named as dotnetviewersample)
>> and openend this application from .Net 2005 .
>> While setting the ajaxviewersample.aspx as start page and opened in the
>> browser
>> it gives an error that
>> Configuration file "C:\Program
>> Files\MapGuideOpenSource2.0\WebServerExtensions\www\dotnetviewersample\dotnetviewersample\../webconfig.ini"
>> cannot be found or cannot be opened.
>> My Doubt is that
>> 1) How this dotnetviewersample application works?
>> 2) How to debug this application?
>> 3) What will be the output
>> Can u plz tell me briefly?
>> if u know the error plz help me.
View this message in context: http://www.nabble.com/Dotnet-viewer-sample-application-problem-tp20480441p20653577.html
