[mapguide-users] ScribbleR2 with different PDF output
djonio djonio at miami-airport.com
Mon Nov 24 07:41:44 EST 2008
Howdy,
For those of you who use ScribbleR2 I have generated an alternative
MaterializeMapPDFPage method.
This will produce three(3) images and one(1) text page in the generated PDF
file.
        byte[] forPdf1 = MaterializeMapImagePage(session, mapname, width,
height, imageflavor);
		byte[] forPdf2 = MaterializeMapImagePage(session, mapname,
            System.Convert.ToInt32(Math.Ceiling(width * .65)),
            System.Convert.ToInt32(Math.Ceiling(height * .65)),
imageflavor);
		byte[] forPdf3 = MaterializeMapImagePage(session, mapname,
            System.Convert.ToInt32(Math.Ceiling(width * .40)),
            System.Convert.ToInt32(Math.Ceiling(height * .40)),
imageflavor);
Preferences are set in the output PDF to show thumbnails and Fit.
The fourth(4) page is the text contents of the Scribble markup layer.
(centroid of geometry)
If you have made no changes yourself you should be able to rename the
existing MaterializeMapPDFPage method that is in scribblemethodsmgr.cs, copy
and paste the contents of the attachment and you should be good-to-go.
r,
dennis
http://www.nabble.com/file/p20660169/MaterializeMapPDFPage.cs
View this message in context: http://www.nabble.com/ScribbleR2-with-different-PDF-output-tp20660169p20660169.html
