[mapguide-users] wms problem
alucas alucas at srtec.com
Mon Nov 24 10:45:04 EST 2008
Hello Kenneth,
The connection works fine for me. I also see the layers, but when I add the
layer to the map, I can't see this layer. The same issue with:
http://ovc.catastro.meh.es/Cartografia/WMS/ServidorWMS.aspx
In both cases, my map is in UTM and the WMS servers have their default
Coordinate Systems in Lat/Lon. So, I suspect that the problem could be with
reprojection.
Do you know any bug related with this?
Thanks.
Kenneth Skovhede, GEOGRAF A/S wrote:
> I can connect to it, and list the layers.
> But it returns no spatial context, eg, no coordinate system.
> I don't know why because the returned xml has a few coordinate systems
> listed.
> I suspect it won't work without a coordinate system.
> You can create a bug report here:
> http://trac.osgeo.org/mapguide/
> Regards, Kenneth Skovhede, GEOGRAF A/S
> alucas skrev:
>> Can anybody connect to this WMS server?
>> http://icvmapas.icv.gva.es/wms
>> I need to connect the schema prueba_wms. I can connect vía AutoCAD Map 3D
>> 2009 and others clients but not with mapguide 2.02.
>> Thanks.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/wms-problem-tp20622404p20663319.html
