[mapguide-users] wms problem
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Mon Nov 24 15:45:12 EST 2008
There is a guide for consuming WMS here:
http://trac.osgeo.org/fdo/wiki/FdoWmsNotes
That is all I know about it :)
Regards, Kenneth Skovhede, GEOGRAF A/S
alucas skrev:
> Hello Kenneth,
> The connection works fine for me. I also see the layers, but when I add the
> layer to the map, I can't see this layer. The same issue with:
> http://ovc.catastro.meh.es/Cartografia/WMS/ServidorWMS.aspx
> In both cases, my map is in UTM and the WMS servers have their default
> Coordinate Systems in Lat/Lon. So, I suspect that the problem could be with
> reprojection.
> Do you know any bug related with this?
> Thanks.
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> I can connect to it, and list the layers.
>> But it returns no spatial context, eg, no coordinate system.
>> I don't know why because the returned xml has a few coordinate systems
>> listed.
>> I suspect it won't work without a coordinate system.
>> You can create a bug report here:
>> http://trac.osgeo.org/mapguide/
>> alucas skrev:
>>> Can anybody connect to this WMS server?
>>> http://icvmapas.icv.gva.es/wms
>>> I need to connect the schema prueba_wms. I can connect vía AutoCAD Map 3D
>>> 2009 and others clients but not with mapguide 2.02.
>>> Thanks.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081124/7b8562aa/attachment.html
