[mapguide-users] Fusion Error When Selecting From Search Results
Eric123
erictsn at cadbeyond.com
Tue Nov 25 00:06:40 EST 2008
Hi Rodolfo M.,
Which file need to be changed "parent.parent.refresh()" by "Refresh()"?
:confused:
Cheers,
Eric
ralph2008 wrote:
> Hi Shamrock,
> I think that you are using the Ajax API viewer instead of using theFusion
> Viewer API.
> The fusion viewer API is the "MapGuideViewerApi.js" and is located in:
> "C:\Program
> Files\MapGuideOpenSource2.0\WebServerExtensions\www\fusion\MapGuide"
> You must referencingt this file in your script and change the some lines
> in your scripts:
> for instances: change "parent.parent.refresh()" by "Refresh()"
> I hope it help you
> Regards,
> Rodolfo M.
> GIS Developer
> Research & Development
> Voxiva, Inc.
> Shamrock Shooter wrote:
>> I am running MOS 2.0.1 with AutoDesk Studio 2009. I created a search
>> button to lookup address from my tax parcels shapefile attribute data.
>> If i run it in the basic layout it works fine. If I run it in the fusion
>> layout, it will populate a list of values in the task pane, but when I
>> select one of the search results, it does not zoom to it in the map and
>> throws me this error:
>> Fusion Error:
>> WARNING: Exception occurred in AJAX callback.
>> SyntaxError: syntax error
>> Location: undefined (737)
>> xx)
>> Can anyone help me out? I tried some searching but didn't find any
>> similar posts.
View this message in context: http://www.nabble.com/Fusion-Error-When-Selecting-From-Search-Results-tp18161869p20675295.html
