[mapguide-users] Possible bug with FDO Provider for MySql
Carmelo Saffioti
csaffi at libero.it
Fri Nov 28 04:42:24 EST 2008
Hi everybody!
I'm using MapGuide Maestro for creating a data connection to a MySql db. When I add a new Dataconnection with "OSGeo FDO Provider for MySql" everything is ok, in fact if I click on "Test connection" I get: Provider reported no errors... I assigned database, server, port, username and password, but there's nothing about tables...
The problem is when, after creating a new layer, I try to choose as feature resource the MySql Dataconnection before created. I get the following error message:
"failed to read schema from data source"
If I use MapGuide Studio for doing the same things, everything works fine! So, is there anything wrong in what I'm doing or is there any bug in Maestro??
Thank you very much in advance
Carmelo
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081128/7d845a77/attachment.html
