[mapguide-users] Possible bug with FDO Provider for MySql
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Fri Nov 28 04:49:14 EST 2008
It looks like a bug in Maestro.
Feel free to create a ticket for the problem.
If you can create something that allows me to reproduce the problem
locally, I will try to fix it.
Are you using 1.0.9 or the newer r3481?
There was a bugfix for database featuresources that is not in 1.0.9.
Regards, Kenneth Skovhede, GEOGRAF A/S
Carmelo Saffioti skrev:
> Hi everybody!
> I'm using MapGuide Maestro for creating a data connection to a MySql
> db. When I add a new Dataconnection with "OSGeo FDO Provider for
> MySql" everything is ok, in fact if I click on "Test connection" I
> get: Provider reported no errors... I assigned database, server, port,
> username and password, but there's nothing about tables...
> The problem is when, after creating a new layer, I try to choose as
> feature resource the MySql Dataconnection before created. I get the
> following error message:
> "failed to read schema from data source"
> If I use MapGuide Studio for doing the same things, everything works
> fine! So, is there anything wrong in what I'm doing or is there any
> bug in Maestro??
> Thank you very much in advance
> Carmelo
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081128/cc1c3797/attachment.html
