[mapguide-users] Possible bug with FDO Provider for MySql
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Fri Nov 28 05:20:54 EST 2008
On the regular page:
http://trac.osgeo.org/mapguide/wiki/maestro/Downloads
Just scroll down to the bottom, and look for "Preview Releases".
Regards, Kenneth Skovhede, GEOGRAF A/S
Carmelo Saffioti skrev:
> I'm using the 1.0.9 version. I wasn't able to find the newer version.
> Where can I find it?
> Cheers
> Carmelo
>     ----- Original Message -----
>     *From:* Kenneth Skovhede, GEOGRAF A/S <mailto:ks at geograf.dk>
>     *To:* MapGuide Users Mail List
>     <mailto:mapguide-users at lists.osgeo.org>
>     *Sent:* Friday, November 28, 2008 10:49 AM
>     *Subject:* Re: [mapguide-users] Possible bug with FDO Provider for
>     MySql
>     It looks like a bug in Maestro.
>     Feel free to create a ticket for the problem.
>     If you can create something that allows me to reproduce the
>     problem locally, I will try to fix it.
>     Are you using 1.0.9 or the newer r3481?
>     There was a bugfix for database featuresources that is not in 1.0.9.
>>     Hi everybody!
>>     I'm using MapGuide Maestro for creating a data connection to a
>>     MySql db. When I add a new Dataconnection with "OSGeo FDO
>>     Provider for MySql" everything is ok, in fact if I click on "Test
>>     connection" I get: Provider reported no errors... I assigned
>>     database, server, port, username and password, but there's
>>     nothing about tables...
>>     The problem is when, after creating a new layer, I try to choose
>>     as feature resource the MySql Dataconnection before created. I
>>     get the following error message:
>>     "failed to read schema from data source"
>>     If I use MapGuide Studio for doing the same things, everything
>>     works fine! So, is there anything wrong in what I'm doing or is
>>     there any bug in Maestro??
>>     Thank you very much in advance
>>     Carmelo
>>     _______________________________________________
>>     mapguide-users mailing list
>>     http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081128/e19fd2dd/attachment.html
